I want more horsepower
Old Aug 18, 2006 | 11:50 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
I was wondering how i can get more horses outta a 305 engine. i dont wanna change engine cause i wanna make the numbers match and gonna be a show car, butwould also like some ***** 2.... i have puttin in a new timing chain, and intake,new water pump and fuel pump, got rid of all the a/c b.s. and the intercooler for a/c (which car runs alot cooler without) and most of all the smog crap to.... any ideas would be great thanks
Old Aug 19, 2006 | 01:14 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
More info on the car,but probably the most HP can be found with the search button.
Nitrous sounds like a good bet. Easy to install, and take off if you ever need to. A supercharger, or a turbo sounds like it might be a bit too involved at this point.
Old Aug 19, 2006 | 12:03 PM
Engine: 355
i tryed some searches u have any sites?? umm wont nitous blow my stock engine its only a 305?
Old Aug 19, 2006 | 12:30 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
from what ive heard everywhere the 305 is tough and will last a while thats why im throwing on a 125 shot kit as soon as it arrives.
Old Aug 19, 2006 | 05:17 PM
Engine: 355
sounds good any oither thingsa u have done to make urs get more horses? any sites for ideas?
Old Aug 20, 2006 | 08:05 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
https://www.thirdgen.org
exhaust, intake manifold, cam, heads, rear axle... not necessarily in that order.
Old Aug 20, 2006 | 08:47 PM
Engine: LO3
well i got a crappy 305 not really extensive mods on it but a bit of a difference. for now ive changed out to 245/50/16 rims and high perform. tires for traction, edelbrock 14x3 open element air cleaner, gutted cat(it was broken), 2.5" Dynomax catback. with these i felt a bit of a difference not too much but has more ***** behind it and sounds hell of a lot better. but my nitrous was sent out today ill let you know how that goes so far the nitrous cost me far less because i got it off a member on this board with it being brand new and a bottle off ebay and still have plenty money left to play with the kit with if i want.
Old Aug 21, 2006 | 11:10 AM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Honestly I wouldnt be so fast to put nitrous on your car. Whether your TPI,TBI, or carb learn how to tune and do a 250 hp build on your car its not too hard with vortec heads a mid range cam and good intake setup. After that turbo/supercharge for more power as needed
Old Aug 21, 2006 | 01:23 PM
Engine: LO3
depends what you got and what you want if you have tpi thats easy to put a turbo/supercharger on compared to a tbi which i think ive only seen 1 person ever with one in one of these motors. nitrous is easy and cheaper than both of those but has risks you have to take and learn how to be safe with it. cams and heads require disassembly of the motor and what not but can be done not too hard. but if you do mod with cams,heads,supercharger,turbo you have to learn how to burn chips to tune your motor to the application
PurelyPMD
May 5, 2016 04:57 PM
dbrochard
Sep 25, 2015 04:56 PM
scottmoyer
Sep 5, 2015 09:33 AM
formula_novice
Sep 5, 2015 03:58 AM
1LE91
Aug 31, 2015 08:13 PM
