nitrous plate or nozzle?
Old Sep 1, 2006 | 11:13 AM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
which would be better? i probably wont go over a 150 shot, but may get greedy and put in a 175.
i bought a used nitrous kit with the TPI plate, but the guy didnt have the extensions for the TV or throttle cable. I know theres a guy around here with an LT1 that i could probably trade the plate for his nozzle, but is that somthing i want to do? if the plates better then ill keep it, but if not then no big deal i guess.
Old Sep 3, 2006 | 12:21 AM
Car: 89 Formula
Engine: 5.7 TPI
nobody has anything?
Old Sep 3, 2006 | 03:49 AM
83 Crossfire TA's Avatar
They’re different…
I like the idea of a plate better, of having things properly aimed and not able to be messed up, but I’m not sure that I trust the machining as much as I trust the nozzles. The other advantage with a nozzle is that you can move it forward in the intake ducting for a softer initial hit if you need to.
Old Sep 5, 2006 | 08:23 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
The plates WAY better. Stick with it, you can get the extension from Auto Zone for 17 dollars that's where I got mine, just get the part number from the NOS 5151 instructions, go in there and order it.
Old Sep 6, 2006 | 09:26 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
If you want to keep the plate, I have an NOS throttle/TV cable bracket extension in my storage unit that I could sell you. It's just a piece of aluminum that bolts to the side of the plenum.
Old Sep 6, 2006 | 09:54 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Originally Posted by 83 Crossfire TA
They’re different…
By forward you do mean away from the TB right...
Old Sep 8, 2006 | 04:55 AM
right
Old Sep 9, 2006 | 09:01 PM
Car: 89 Formula
Engine: 5.7 TPI
thanks everyone, i didnt realize that aluminum piece was what i needed. i already had it. got everything put on today using the plate
too bad the stupid car wont run
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
