my 1/8 mile pass
Old Sep 6, 2006 | 03:23 AM
stroked383z's Avatar
my 1/8 mile pass
took it last friday night to see what it would do , ran a 7.05 at 109mph w/ crappy 60 ft of 1.9 what do you think , w/ some good slicks what kind of 60' times should i get and what kind of times should i expect
Old Sep 6, 2006 | 07:42 AM
Time2Fly's Avatar
Car: 1991 Z28
Engine: 400 ci LS3
Transmission: Jerico DR4
With that trap speed, you should go 6.50s easy.
Old Sep 12, 2006 | 11:56 PM
thats what i'm hoping for, it'll be a couple weeks before i can take it back to the track, they told me before i could come back i needed roll cage and 5 point harness
Old Sep 13, 2006 | 12:38 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Those are some respectable times no less! Whats done to your 383?
Old Sep 13, 2006 | 10:12 PM
check out my garage , i have listed everything in there
Old Sep 13, 2006 | 11:18 PM
izcain's Avatar
Engine: 584
Thats cool man you have a really close setup to what I have as well. I am pulling the 9 inch and putting 4.10's in it right now going from 4.56's little to tached out in the 1/4. What CFM dominator are you running?
Old Sep 20, 2006 | 12:38 AM
its a 750 dominator
Old Sep 22, 2006 | 11:51 PM
superramvette's Avatar
109 MPH is good for low 6's . I trap 103 and run 6.61 with a 1.48 60 foot
Old Sep 23, 2006 | 02:14 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I don't trap that in the 1/4
Nice
Old Sep 30, 2006 | 01:17 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
mph prolly a few high due to the low 60ft.
depending on raceweight, you should be good for 6.4x.
buddys ls1 s10 bracket truck runs 6.28 at 110. dunno if you can squeeze that or not.
good luck!
Old Oct 8, 2006 | 05:25 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I blew my posi last night and was running an open rear. I managed a 1.613 60' time. Went 6.93 @ 107.65 mph. Will this go 6.40's or 50's?
Old Oct 8, 2006 | 05:40 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Originally Posted by 94-6spd
I blew my posi last night and was running an open rear. I managed a 1.613 60' time. Went 6.93 @ 107.65 mph. Will this get go 6.40's or 50's?
107mph will yes.
Old Oct 11, 2006 | 09:24 PM
don't know yet i will let you know when i get some drag slicks , m/t et street radials don't do anything for me
Old Oct 13, 2006 | 10:41 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
You wouldn't happen to have manual trans with those et street radials would you? My friend had et street radials on his modded Z06 and could never hook. He ended up calling M/T and talking to a tech guy because we thought it might be air pressure or burnout procedure could be causing this. Turns out that the radials can't take the shock of dumping the clutch at 5 or 6 thousand. He put on some regular ET streets and started getting 1.5 60' times immediately with no other changes.
Old Oct 13, 2006 | 08:22 PM
i've got a 350 turbo w / trans brake coming out of hole at 4200rpm, next time i run it i will foot brake it to see if coming out of hole at lower rpm will help i'm trying to hold off on buying drag slicks cause i will probably run it next fri and be done for this season
92GTA
Apr 9, 2016 07:39 AM
kairles
Oct 26, 2015 09:13 PM
69 Six Pack
Oct 5, 2015 07:51 PM
WIzmo
Aug 30, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
