Biggest dry shot sprayed in a 305?
Old Sep 12, 2006 | 12:10 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have a 305 tpi, my mods are below.
On Sunday, I sprayed a 145 dry shot with a Zex dry kit.
BTW, I have 24 LT1 injectors, so I have not maxxed my injectors yet.
I have a buddy with a '92 Mustang LX that sprayed a 150hp as well.
What is the biggest dry shot anyone has sprayed in a fuel injected engine?
Old Sep 12, 2006 | 06:28 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
This won't apply to you but a friend sprayed a .078 jet dry through the MAF on his LT1 car. He did this bottle after bottle after bottle and the car never complained.
Old Sep 12, 2006 | 07:16 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Do you know what kind of a kit it was? Zex, NOS, NX?
Old Sep 12, 2006 | 07:27 PM
It was an NOS Pro Race solenoid with 6an line running to it, it had about a 3in metal direct port style bend coming out of the bottom to the fitting with the .078 jet. We drilled out the jet to a .092 later but never got to use it because he traded the car off. The car did a 12.6 on this setup with street tires and a turbo 350.
Old Sep 12, 2006 | 10:24 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
It sounds like a wet kit to me.
Did it have a nozzle in the intake tube and ONLY spray nitrous?
Old Sep 13, 2006 | 03:35 AM
Yes it was a dry kit. He was spraying the nitrous ONLY through the MAF sensor. It didn't run like yours with the bypass line to the FPR it relied solely on the temprature of the nitrous to add additional fuel via the MAF. He had a set of LS2 injectors from a 06 GTO in it and an MSD 6 box, that was pretty much it for his mods. He sprayed it on 91 octane and probably ran out 6 10 pound bottles of nitrous. The car was a glory grenade that refused to go off it was amazing.
P.S. The kit was a rig together made out of a direct port system, the solenoid would've flowed up to a .120 jet and with the extremely short hard line the kit hit extremely hard.
Old Sep 13, 2006 | 10:21 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Anyone spray a big dry shot on a 350 or bigger motor?
Old Sep 15, 2006 | 06:45 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Anyone?
Old Sep 15, 2006 | 10:11 PM
nonsocial's Avatar
Car: 90 Camaro RS
Engine: small block
Transmission: TH350
dry shots for the lose!!!!!!!!!!! wet is the only way to spray>
Old Sep 15, 2006 | 10:53 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Why are you trying to turn it into a bad thread? Dry shots can be good with the proper setup. Lack of knowledge is bliss I guess.
Old Sep 15, 2006 | 11:09 PM
nonsocial's Avatar
Car: 90 Camaro RS
Engine: small block
Transmission: TH350
i wasn't trying to make this a bad tread. sorry. dry shots are fine as long as you use a a/f mesurement device and correct the lean mixture using other means. i've used them before and i just believe it is easier and cheaper to go wet if you going over 100 or so. lack of knowlage? don't be so harsh
Old Sep 15, 2006 | 11:22 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Congrats on adding absolutely nothing to this post.
Old Sep 16, 2006 | 05:06 PM
Just as a note, a .078 jet is a 230hp shot.
Old Sep 16, 2006 | 11:24 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
what about on a diesel
Old Sep 30, 2006 | 01:19 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
buddy danny is TRYING to blow his 305 up with a 175 wet kit. it wont die.
he is waiting on the motor to go before his 6.0 goes in.
Old Sep 30, 2006 | 01:22 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
LQ4 and LQ9's are the ****!!!!
Old Sep 30, 2006 | 02:02 PM
Tell him to get a big solenoid and go up to an 82 jet, if that doesn't do it go up to a 98 jet that should do the trick and be fun while doing it.
Old Sep 30, 2006 | 04:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
So LB9GTA - your biggest used was a...150 shot? before the big bang?
Old Sep 30, 2006 | 07:15 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
The biggest dry shot was a 145 shot.
When my tranny wouldn't shift into 3rd, I was spraying a 125. That's when she blew.
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
