What is better?
Old Sep 24, 2006 | 01:47 PM
92fireformula's Avatar
Car: 92 Firebird Formula
Engine: 5.0 tpi
What is better?
What is better a supercharger, turbocharger or a procharger?
Old Sep 24, 2006 | 10:30 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Procharger is a brand name supercharger.
Turbo vs. supercharger debate has been discussed a lot here. Each has its own benefits. Best thing to do is search.
My personal preference lies with turbos.
Old Sep 25, 2006 | 08:19 AM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Axle/Gears: 9 bolt 4.11
Turbo!!!! It also adds points to the "cool" factor!
Old Sep 25, 2006 | 06:34 PM
Engine: 5.0 tpi
I heard you have to take out your a/c with a turbocharger.
Old Sep 25, 2006 | 07:14 PM
vwdave's Avatar
Nah, not really. I am not taking mine out.
Old Sep 25, 2006 | 07:31 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
It's an opinion issue.
Old Sep 25, 2006 | 10:36 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
If I was to buy another supercharger I would want to try the D1SC.
Old Sep 26, 2006 | 08:46 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
That all depends on placement of the turbos.
Old Sep 26, 2006 | 11:20 AM
Drac0nic's Avatar
Can you design and fabricate your own system? If so a turbo system may be for you. If you don't have access to even moderately decent facilities (read:welder) and have the skills to use them then such an option may not be for you. The advantage of a SC kit is that they're "bolt on and go" while a turbocharger system when properly implemented should have overall higher efficiency, easier to adjust boost levels and more access to aftermarket parts. (you're not stuck with a particular company when you want to upgrade)
