Turbo Confusion
Old Oct 29, 2006 | 10:30 PM
E-Z Rollin's Avatar
Turbo Confusion
I've read turbos l,ll & lll and even played with some of the math calculations but I must admit that picking a turbo can be confusing. I relize that choosing a turbo has to do with your intended useage:mild street,hp street or racing. Anyone know of a turbo calculator that takes these factors into consideration?
Old Nov 10, 2006 | 12:38 PM
83 Crossfire TA's Avatar
What the hell is turbos I, II and III?
Old Nov 10, 2006 | 05:57 PM
AtomicZebra's Avatar
Well, while I was reading about the MegaSquirt fuel programmer I came across a calculator like that, the only problem is there is no direct link so here are the directions.
1. Go to http://www.megamanual.com/v22manual/mturbo.htm
2. About 8 paragraphs down there are a couple of hyperlinks.
3. Find the Ray Hall Turbocharging link.
4. This will bring you to a couple of different calculators.
5. Click on the Turbo Match calculator, you fill out some simple engine information and they reccomend a turbo for you.
Hope this is what you were looking for and helps with your turbo choosing.
Old Nov 10, 2006 | 07:07 PM
E-Z Rollin's Avatar
Try TurboByGarrett.com for Turbos I - II - III. Thanks for the megasquirt and ray hall tip I had found them since this post some good info there.
Galaxie500XL
Feb 1, 2020 04:53 AM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
bubbaz28
Sep 18, 2015 02:09 PM
