tpi Nos Plate
Old Dec 23, 2006 | 11:45 PM
house's Avatar
Car: 1988 Iroc Z
Transmission: coan racing 700r4 coan 2500 stall
Axle/Gears: 9 bolt with 3.27's
tpi Nos Plate
where can i get a Tpi Nos plate that will handle up to 200-250hp the regualr ones from nos say 150 will a lt1 plate work?
Old Dec 24, 2006 | 01:05 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
tpi won't have good fuel/nitrous distribution to run that big of a shot through it. That's fogger territory, not sure how guys run foggers on tpi's though.
Old Dec 24, 2006 | 09:44 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
ive seen the nozzles tapped into the runners, but i have a feeling that would creat too much puddling of the fuel because of how sharp of a curve they are. the only way i can see you getting up that much, is running a 2 stage dry/wet system.
Old Dec 24, 2006 | 10:15 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Use this,
Or the TPI plate and the above setup for a dual stage setup.
Old Dec 24, 2006 | 02:53 PM
house's Avatar
Car: 1988 Iroc Z
I am going to the stealth ram soon also, but for now want to get nos on the tpi, i hacve 400hp NX kit on a gas truck i am taking off and gone use all the line and solinoids from it, all i need is a plate to handle 200hp
Old Dec 24, 2006 | 04:45 PM
Zepher's Avatar
My plate will do a 200HP shot, just put 100hp jets into each nozzle and away you go.
Plate has the lines to the solenoids and there is one nozzle, I traded the other nozzle as part of a nitrous kit to a friend for some wheels.
Make me a reasonable offer for the plate setup if you are interested in it.
Old Dec 24, 2006 | 05:00 PM
house's Avatar
Car: 1988 Iroc Z
do you have the jets and is that fogger nozzles?
Old Dec 24, 2006 | 09:59 PM
Zepher's Avatar
I don't have any jets, and those are NOS fogger nozzles (I only have one).
the nozzles look identical to the ones on my old Direct Port setup,
Old Dec 25, 2006 | 04:10 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
The NOS plate for the TPI is a cheater plate and WILL handle a 250 shot. I heard this directly from NOS so it's not hearsay. You will get some pretty funky distribution with that big of a shot through a plate but I've done 200 with no issues as of yet.
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
Sanjay
Aug 12, 2015 03:41 PM
