Another 144 Question
Old Jan 27, 2007 | 02:40 PM
EndlessSummer85's Avatar
Car: 1982, 2000 Trans Am
Engine: 350 bored .040 over: LS1
Transmission: Borg Warner Super T-10: Tremec T-56
Axle/Gears: 4.10s; 3.42's
Okay so I finally decieded on the setup for my TA. I want to go with a weiand 144 blower, the question I have is what hood will I need??? 2'', 2 1/2'', 4'' cowl???? I've done many searches and haven't found what will fit. If I could I would rather go with a shorter cowl, but will go with the 4'' if I have to. I plan on getting MSD 6AL ignition, with a boost retard control box, gonna go with a 12 bolt 3.42 gears, and maybe a little spray (50-75) or methanol inj. for strip use. Also if anyone has any pics on their 3rd gen, please post. Thanks
Old Jan 27, 2007 | 07:59 PM
Damon's Avatar
I just about barely squeezed it under the hood of my 78 Malibu with a 2-1/2" cowl- and that was playing a lot of air cleaner games and still rubbing ever so slightly on the underside.
Your 3rd gen Camaro has less hood clearance than my Malibu to begin with so I'd say a 4" cowl hood for sure.
Old Jan 27, 2007 | 08:10 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
Damon, you have a 142 rite? Isn't the 144 a little shorter
Old Jan 28, 2007 | 01:58 PM
Yea it's supposed to be about 1/2'' shorter, but someday I'll have a no2 plate there
Old Feb 13, 2007 | 01:13 PM
DaGoat's Avatar
I've got a 142 in an '86 T/A and the top of the carb rubs on the underside of the hood. The ring that the aircleaner sits on sticks up above the hood. I don't have a good picture on this laptop otherwise I'd show you.
Old Feb 13, 2007 | 05:18 PM
Damon's Avatar
Yeah, the 144 sits the carb about 1/2" lower than my 142. Not enough to make a big difference- you still need a good sized cowl hood to clear it on a 3rd gen.
Old Feb 13, 2007 | 08:05 PM
Yea but that shouldn't be a problem. I'm gonna get a 4'' cowl, that should hide it all. I can't wait to get it done, just gonna be a while to save up.... I Gonna def. be different though.
Old Feb 14, 2007 | 09:16 AM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Oops, wrong thread. And I thought I had mastered the 'back' button.
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
CORV3TT3
Aug 23, 2015 11:26 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
