turbo terms
Old Mar 26, 2007 | 11:02 PM
stevemicaelo's Avatar
turbo terms
is there a web site that i can read up on turbo terms like a/r,trim etc.
i want to learn more so i can pick the proper turbos for a twin setup.
or if you have any suggestions.
383
10 to 1 right now going to probably lower it to about 9 to1(any suggestions)
will change cam
have stock rods but will change those also.
have steel eagle crank so i am guessing it will be alright.
want about 450 500 rwhp
and no more than 6000 rpm.
i also got a holey stealth ram but have not bought injectors or the tb yet.
thanks
i did search
Old Mar 27, 2007 | 03:03 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
Re: turbo terms
383
will change cam
thanks
i did search
i'd replace that stealth ram since it has holes in it.
if you want to cut to the chase, call a company that sells turbos for a recommendation, like Pro-Turbo Systems etc.
Old Mar 27, 2007 | 05:39 PM
DIGGLER's Avatar
Re: turbo terms
just wondering what you meant by this...
Old Mar 27, 2007 | 07:18 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
Re: turbo terms
he said it was "holey"... it was a joke.. he meant to say "Holley"...
Old Apr 3, 2007 | 04:04 PM
hereinmissoula's Avatar
Re: turbo terms
turbomustangs.com with any questions...
sure you will get answered there and they have some good stickies on turbo termonology sp???, lol
Old Apr 8, 2007 | 01:26 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: turbo terms
"Maximum Boost" by Corky Bell is a really good book to read. Good to have in the house for your calculations as well. It's pretty technical, but if you're going to install your own turbo system, (seriously, not just talk about it on the internet), then you'll want to read it cover to cover.
Drop your CR to as low as you can. With a 383 and the long stroke that gets tricky, but I know there are 22cc dish pistons IIRC, that will bring you to 8.3 or so, with 76cc heads.
How's it looking in beautiful Kelowna? I can't wait to go back to the Okanagan this summer, the snow in Calgary is killing me!
Old Apr 8, 2007 | 01:29 AM
Re: turbo terms
thanks i will find the book.
kelowna is awesome yesterday was 21 and today was 24 and clear
cant beat the okanagan its awesome.
Old Apr 8, 2007 | 09:09 AM
firstfirebird's Avatar
Re: turbo terms
You can keep your 10:1, just have to run less boost. I'm in the process of gathering parts to make a high compression boosted hybrid (FWD/RWD). Guys with FWD V6's are running boost on stock, high mileage, 9.6:1 or more compression without problems.
I agree with Sonix that you should do some research before you go bolting/welding stuff up. Not to discourage you, mine is getting built in my driveway.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
hartsmike
Oct 4, 2015 01:00 PM
BWilcox
Sep 20, 2015 12:19 PM
