tbi nitrous users respond
Old Apr 14, 2007 | 01:03 AM
sp63
Guest
Posts: n/a
i want to hear some stories on what kit you bought and thoughts on the install. i am looking at a couple of options here
one :
$522
basic plate system set up like a carbed nitrous kit:
http://www.barrygrant.com/nitrous/default.aspx?page=97
this is what i was leaning for until i saw the nx kit which i like the looks of better, but its 200+ more for the nx kit..
two:
$757
http://www.nitrousexpress.com/Pages/gm_tbi.htm
i like the fact that this kit does not modify the height of the top of your engine, usefull for those running a 3in air filter...
also like the fact that it has adapters for threading the nozzle into the gold ring. also one problem with the tbi unit is the lack of a schrader valve. this kit has a T fitting schrader valve. so its basically a twin nozzle kit with a valve for a test fitting included. otherwise like on the others im gonna have to either T in with my own stuff or use whatever tbi specific parts they include (nitrous works only.., the other ktis will get a standard brass 3/8 tee)
the next two are super cheap for some reason.... :
http://www.dynotunenitrous.com/store...?idproduct=215
this is the dyno tune kit, it has the "adapters" for threading into the gold ring also... cost is $399 ????????????????????????????????
http://www.nitrousoutlet.com/catalog...roduct_id=2529
this one also comes with the nozzle adapters, which make it appealing but the price is more than the others at $580
any body got any input on which system i should go with? i wont be purchasing until the end of this month so i have some time to look around for reviews on the various brands and whatnot..
Old Apr 14, 2007 | 01:24 AM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: tbi nitrous users respond
i have a tbi NOS nitrous kit. i love it got it off a member here for real cheap. set it up within 2 days taking my time and only working like 2 hours a day. the tbi plate is nice if sprays where you want it to i wouldnt do above the injectors but thats just me. plus my 14x3" air cleaner still doesnt touch my firebird roof
Old Apr 14, 2007 | 01:28 AM
sp63
Guest
Posts: n/a
cool. good to know. the nitrous works kit is cheaper than the Nos tbi kit. by say 50 bucks....
it is also a spray bar / plate design.
also theo ther kits with the nozzles dont spray above the injectors they spray level with them so fuel and n0s isnt going on the wiring of the injectors. i was wondering about that also but i found out.
Old Apr 14, 2007 | 11:34 AM
Engine: LO3
idk id say go with the nitrous works tbi kit ive looked at it before but ended up just getting the NOS kit because i got it for one hell of a deal but go with the plate youll be a lot happier its much easier to install and it all set nicely.
Old Apr 14, 2007 | 11:45 AM
sp63
Guest
Posts: n/a
cool man, see i was debating on if the spray bar would atomize the stuff as good as a nozzle but i guess it does. so far its lookin like imma get the nitrous works kit.
Old Apr 14, 2007 | 12:14 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
The NX kit may not have the plate, but from what I've read, NX stuff is a step above the other brands.
As you mentiond, I'm already eating into my hood liner with my 3" K&N, so adding anymore height to my TBI is not good unless I want to drop money on a new hood.
Old Apr 14, 2007 | 07:31 PM
sp63
Guest
Posts: n/a
well i dont have a hood liner anymore. that frees up like an extra inch of space.
also, if i do get the spacer piece, i can always remove the gold ring above. they are about the same thickness...
Old Apr 15, 2007 | 02:34 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
interested in kit..i have an 89 305 TBI camaro. is basically stock. would this motor handle it and what exaclty would i need to get this to work? pics?
Old Apr 15, 2007 | 05:39 PM
Engine: LO3
everything is included in the kit that would make it work. basically hook it up and wire it up fill the bottle and have fun. o yea retard the timing some and get a step colder spark plugs. id say to be SAFE a 100 shot is fine especially on the stock pump. i ran i think a 130 shot last year on my stock LO3 with stock pump and it was fine im upping to 150+ this year with a 190lph which should be interesting and yes idc if the motor blows.
Old Apr 15, 2007 | 05:54 PM
sp63
Guest
Posts: n/a
man i wasnt gonna buy my kit till the 27th of this month when i get paid but my mom said i could put it on her CC and then pay her, but i kept reading abotu bottle heaters and pressures and whatnot. and i think those are VERY essential things now. from what i have found a gauge and heater is going to cost about 160 extra. i cant swing that right now (have to limit 500 per check basically, rest goes to savings). anyways, i got to thinking hmm... everyone says the nx kit is great blah blah blah, it uses the dual nozzles into the tbi via the gold ring, OK, the Dyno tune kit uses the EXACT same setup. for over 100 less...
i have money ion my hand + my moms CC i can get the heater, gauge, and kit all in one go. only other thing is the window switch. which i also think is nec. but its another 150+ . damn.
so heres my list right now:
kit $389
Heater $109
http://www.dynotunenitrous.com/store...p?idproduct=17
Gauge 58
http://www.jegs.com/webapp/wcs/store...53511_-1_11289
i think this would be a good setup aside from the fact that you have to roll into the throttle to get over 3000rpms before flooring it.
Old Apr 15, 2007 | 09:35 PM
sp63
Guest
Posts: n/a
http://www.harrisspeedworks.com/shop...cat=364&page=1
this kit looks good, has GOOD reviews on ls1tech, similar price, AND includes the gauge....
interesting.
edit: the bottle heater is 20 bucks more here but looks better than the dynotune stuff.... plus the website has good reviews. which is a big plus i think. and its all in my price range.
Old Apr 16, 2007 | 10:44 AM
Car: 91 RS
Engine: 350 TBI
kit $389
Heater $109
Gauge 58
You get what you pay for.
Old Apr 16, 2007 | 03:34 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
anybody have any engine pics of this nitrous setup? basically buy the kit wire and screw everything into my stock lo3 and go? that sounds WAY to easy. so basically headers exhaust better air intake and nitrous and you can have one hell of a 305 tbi? what kind of horsepowe?
Old Apr 16, 2007 | 03:58 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
how many times can you change jets?...
Old Apr 16, 2007 | 04:28 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Stay away from the Dynotune stuff, I've seen 2 Dynotune solenoids leak and they apparently have no customer support. A bottle heater is NOT that necassary. Run hot water over the bottle in your bathtub before you leave and wrap it in a towel. If you're in town and you need to get the bottle warm, throw it in the floorboard with the heat on it for a few minutes problem solved. As for the jets, you can change then indefinetly as long as you don't strip anything *which you shouldn't*.
Old Apr 16, 2007 | 05:40 PM
Car: 91 RS
Engine: 350 vortec
i meant you could have as much HP out of a N02 system as you wanted as long as you could change jets... not how many times can you acctually change jets
Old Apr 16, 2007 | 06:48 PM
sp63
Guest
Posts: n/a
car has no heater core.
htr is nec. lol.
Old Apr 16, 2007 | 09:35 PM
Engine: LO3
ok well i recently redid my setup and neither the purge or the wiring for any of it has been done so this is how it looks as is. and ill give a before pic where they were over the exhaust manifolds.
new setup:
old setup:
im about to dyno my car in about a month id say but im hoping with a .067 nitrous jet that ill hit 300 to low 300's whp and well over 400+wtq
Old Apr 17, 2007 | 05:49 AM
sp63
Guest
Posts: n/a
what all do you have to to your car?
basically i have.. the intake and a shift kit with someo ther trans work.
what kind of mileage is on your car? did youh ave to replace your fuel pump? what fuel pressure are you at these days? and uh.. what is your fuel pressure saftey switch set to (if you have one). i was wondering if the carb (5psi) switches could be adjusted up to like 12psi.
did changing to headers make a big diff on/off the nitrous ?
Old Apr 17, 2007 | 02:17 PM
Engine: LO3
im running a .067 nitrous jet
im running 13 psi of fuel pressure
i have a 190lph pump to support all this
i havent run it with the headers yet but i will not be able to tell the difference since im getting lower gears and upped the jets.
i basically have intake and full exhaust
56k miles on my car.
no fpss for me
Old Apr 17, 2007 | 05:21 PM
sp63
Guest
Posts: n/a
ok i have 156k miles, LOL.
i do think im gonna get a fuel pump in the next few weeks.
i want to do gears but i dont think its worth it on the stock rear end. it WILL eventually break.
Old Apr 17, 2007 | 08:03 PM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Wha fuel jet are you using with a .067 nitrous jet? That is good for 200 hp that size jet. I have a .057 and NOS says that is a 150 shot or so, maybe 160. Also, what fuel jet you running, are you using a TBI plate?
Old Apr 17, 2007 | 09:04 PM
Directly from NOS, a .070 jet is a 150 shot. NX jets differently theres are always lower, Nitrous Express is even lower still. The headers will make a very big difference on these cars with nitrous because the factory log manifolds suck horribly, nitrous just makes it worse. I spoke with a representative at NOS about my 5151 TPI kit and was told that a .078 jet was a 200 shot and the .073 jet I was running was around a 180 shot. The TBI kit has shorter lines to the plate but this isn't going to make a hugely dramatic difference in the jet size, just how hard the nitrous comes on.
Old Apr 17, 2007 | 09:13 PM
liquidh8's Avatar
Transmission: 2004R
Oh ok, you have a tpi kit. I talked to a NOS rep about the TBI plate, he said I should max it at 150. I have the BBC plate w/2 in bores. I have cheater noids on it, so the capability is there for 250 hp, but I can't with that plate. I may use the squarebore cheater plate under the tbi adapter. Haven't heard anyone talk about how that worked out though.
Old Apr 17, 2007 | 09:37 PM
The plate under the adapter will work out fine. Also the passages in your cheater solenoids are quite a bit larger so that could effect the jetting of the system. I'm fully maxed at my solenoids by the .073 jet. I have a set of large Top Gun solenoids that will flow alot ready to go in along with a .078 jet and we'll see where that puts me. I've sprayed this TPI engine into the low 12's on a bone stock long block with high miles. This year I'm gunning for 11's.
Old Apr 17, 2007 | 09:44 PM
liquidh8's Avatar
Transmission: 2004R
Cool, good luck. I just have to get to the track. Should be in the low 12's with the juice. I ran a few low 13's last time out, with street tires on 17 inch rims @ almost 4000 lbs with me and a full tank. I've since put a glass front bumper on the front, and did some more tuning. I few more n/a runs then I'll try the n2o.
Old Apr 17, 2007 | 10:16 PM
Engine: LO3
i do have the tbi plate. i have the cheater solenoids that came with the kit. i havent tried my new jets yet and i dont remember which fuel jet i put in there but i calculated it. also im putting in a stock 3.08 posi drum rear rather than my 2.73s i dont want to mess with internals or disc conversions just yet. so if it blows it was well worth the 100 i got it for.
Old Apr 17, 2007 | 11:35 PM
Vipershark those aren't the cheater solenoids, those're the powershot solenoids. The cheater noids are bigger.
Old Apr 18, 2007 | 12:31 AM
sp63
Guest
Posts: n/a
so.. back to my thread. in the next few days im gonna drop cash for the harris speed works dual nozzle kit and heater.
im getting that cant wait feeling in my skin....
hah
Old Apr 18, 2007 | 09:39 PM
Engine: LO3
oops my bad i dont know why i thought otherwise. so how much can those flow max?
once you put the nitrous on youll be hooked and always want more trust me in the beginning i denied it and said id be happy and i was for 1 summer my friend told me id want to up it i said no. now look at me. im a nitrous junkie
Last edited by vipershark11; Apr 18, 2007 at 09:40 PM. Reason: Automerged Doublepost
Old Apr 19, 2007 | 12:17 AM
sp63
Guest
Posts: n/a
im getting there. lol.
i bought me a fuel pressure guage today, now i have to figure out how to watch it while i go WOT...
im feelin, run it on a line up by the side mirror lol.
Old Apr 19, 2007 | 01:18 AM
You should be able to run it up to the cowl, you really only need to watch it a few times, just get going in 3rd at full throttle and spray it, that'll show you the minimum it's going to run down to. Vipershark your solenoids have .073 passages inside. Going over .073 on the jets really doesn't help unless you upgrade solenoids.
Old Apr 19, 2007 | 09:18 PM
Engine: LO3
ok then my .067 jets will be plenty enough for this year.
Old Apr 19, 2007 | 09:53 PM
sp63
Guest
Posts: n/a
ok i got it installed (the guage) today and my fuel psi is set on 12 psi. i have no way of knowing what it goes to when i drive until i get the lines to run it up to the cowl area. gonna duct tape it to the window LOL.
how much of a drop can i expect when i spray the first time? im debating on buying this like. 30 dollar in line pump from autozone, do you think it would make it safe?
Old Apr 20, 2007 | 08:17 PM
The 30 dollar inline pump will probably just hinder your ability to pump fuel. They're only made to run like 7psi tops. If you want to do an inline get one of the Walboro 255 regular pressure pumps, apeusa sells them and you can get them elsewhere online at a good price.
Old Apr 20, 2007 | 10:33 PM
sp63
Guest
Posts: n/a
thats where my gauge was, i ran a line from that t up to my cowl and mounted my gauge (with ducktape) to my window and i did some WOT runs up to like 105mph, quick question, when it was mounted down like in the pic, i got 12psi, now its mounted at the cowl and i have 11.5psi. is that a sign of a bad pump?
Old Apr 21, 2007 | 04:29 PM
sp63
Guest
Posts: n/a
i left my gas cap loose to relive pressure during my gauge relocate. its up to like 11.75/12psi now.
Old Feb 2, 2018 | 11:26 PM
srv010's Avatar
Its now 2018 and I'm not able to find a TBI injection Plate to under my TBI. I have an 1989 firebird trans am. I bought a kit from summit and it came with a plate for TPI not my TBI system. What am I to do?
Old Feb 3, 2018 | 01:53 AM
Drew's Avatar
http://www.jegs.com/i/NOS/741/05153/10002/-1
Or Ebay, or want ad in the classifieds, etc
Old Feb 3, 2018 | 02:00 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
It might be still for sale
https://www.thirdgen.org/forums/engi...s-plate-f.html
Old Feb 28, 2018 | 11:51 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I'm using a Cold Fusion nitrous kit on mine. Single fogger nozzle but they have plates if you want to go that way. I am very happy with the quality and durability of the components. Been on the car for around 10 years or so and no problems with solenoids or any other component.
I am running EBL flash ecm and it has great N2O control features and can be configured for TBI cars. Check out dynamicefi web site for info.
evilstuie
Jan 9, 2020 08:29 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
Night rider327
Sep 2, 2015 04:17 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
