Open downpipe or run a muffler on a Turbo car?
Old Apr 15, 2007 | 07:59 PM
RoadHammer's Avatar
Car: 1991 Camaro Z28
Axle/Gears: stock
For you guys running turbos in your 3rd gen,
Are you runnnig open downpipe(s) or are you running full exhaust (cats, mufflers, etc.) after the turbo?
Old Apr 15, 2007 | 10:58 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Open downpipe or run a muffler on a Turbo car?
well i think it is personal choice you know depending on how you plan to use the car... i mean a daily driver i would throw on something wether it is something like purple hornies or thrush glass packs... something probably not a flowmaster or other chamber muffler. but then again somepeople think the turbo quiets the exhaust down enough all by it self
Old Apr 16, 2007 | 09:57 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Down pipes through open boom tubes. Links to vids/sound clips in my dyno thread here, and boom tube fab thread in the exhaust board. Open dumps too... It's a bit loud for street driving.
Old Apr 16, 2007 | 01:37 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
here is a link to my car straight out the downpipes..
http://www.bartonekdragracing.com/we...amarofront.mpg
its actually not that loud.. I put mufflers on it though and its REAL QUIET. Hooker aero-chamber mufflers.
Old Apr 18, 2007 | 06:29 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
I have an electric cut out where the factory cats were. Then i have a slp cat back. Very nice sound with the cutout closed, not too loud at all. Then its really loud with the cut out open, best of both worlds. I get 3-4 more lbs of boost with the cut out open, proving that mufflers do restrict somewhat.
Old Apr 18, 2007 | 06:36 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
On my TTA I had a dump before the cat, with an electric cutout. Worked great! Mostly helps exhaust restricted cars. A good 3 in exhaust, hi flo cat and 3 in dp should get very close to the electric dump(performance wise).
Old Apr 19, 2007 | 07:25 PM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
on my subaru i have a stock cat-back and then when i want to make some noise it has a 3inch cut out. If its a race car, just run an open dp it will make some serious top end
Old Apr 22, 2007 | 03:48 PM
RoadHammer's Avatar
Axle/Gears: stock
I like BDR's setup in that vid there but I am concerned that if I go with a muffler that is too loud my car will become a cop magnet, and the cops here are ******.
I want something quiet yet not hurt flow too badly. My Camaro will be driven on the street as my summer car and prolly a few strip passes.
Old Apr 23, 2007 | 10:55 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
if you want to hear it w/mufflers...here ya go:
http://www.bartonekdragracing.com/we...o_reverse3.mpg
thats w/hooker aerochamber mufflers.
Old Apr 25, 2007 | 06:25 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
The Dynomax Ultraflow is very popular as a turbo muffler - a little louder than the Hooker, but seems to flow much better. To pass tech for LimeRock, I needed to quiet it down to 83 dBa at 5000 rpms and 50'.
From http://www.skulte.com/z28tt/archives..._testing.html:
This afternoon I drove over to my old place of employment, and we used the nice spectrum analyzer to check the sound level for the upcoming LimeRockPark time trials. From 50' to the side, it's at 75 dBa at idle, and 92.5 at 5000 rpms. From the rear, it's 83 at 2500 and 87 at 5000. Inside I get 95 dBA at 5000. LRP's limit is 83 at 50' and 1000 rpm shy of redline. My next option is to put a deflector plate aiming the exhaust at the ground, to see if that helps. If not, then a muffler, or just short shift it.
Exhaust summary: iron manifolds, turbos, 2.5" downpipes, 3.5" y-pipe, to ovalized tubing, and out the side with a 1.5"x8" boom tube.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
makaveli09
Aug 12, 2015 09:07 PM
Exxon Limited
Aug 9, 2015 08:13 PM
