E85 blow through carb
Old Apr 25, 2007 | 01:08 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I was interested in doing this, but I've been advised against it by aedperformance. They said there just hasnt been enough R&D on it, and since it is somewhere in between meth and gas, neither carb will really work well. Also said that E85 is not regulated at all, which causes tuning problems.......so I guess its back to gas.
So here is a question, could I inject E85/water instead of meth?
Old Apr 25, 2007 | 05:05 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: E85 blow through carb
why would you? meth is very available.. you just need to know where to look. and its cheap
Old Apr 25, 2007 | 05:09 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Does meth provide better cooling than ethanol?
Old Apr 25, 2007 | 09:00 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
funny cuz all the turbo guys are going nuts. check out turbobuick.com they have TONS of different chips/timing/fuel tables out there for it. it's not regulated on octane, sometime it'll be 106, sometimes 111 but if you're not on the ragged edge you'll be fine. Call quick fuel carbs and they'll set you up no problem for the carb parts.
Old Apr 25, 2007 | 10:11 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
http://www.theturboforums.com/e85dyno.php
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
90formulaVortec
Sep 3, 2015 09:26 AM
