How do I know what size ATI pulley I have?
Old May 1, 2007 | 07:25 PM
5.7iroc-02ws6's Avatar
Car: 1988 IROC/02 WS6
Engine: zz3 crate w/12 psi ATI and stock ls1
Transmission: 700r4 w/2800 stall and m6
Axle/Gears: 3:42 10 bolt-both cars
No markings that I can see on the pulley... I measured from outside edge to outside edge and it is "4.00... Is that the actual way to measure... I am looking at a 3.85 pulley to up some boost but not sure of what I have now?
Old May 2, 2007 | 01:46 PM
KS91Z28's Avatar
Re: How do I know what size ATI pulley I have?
ProCharger measures their pulleys going from the top side of the ribs. The shoulder that you measured stands approx. .2" taller than the ribs. So if you measured 4", then you need to subtract .2" from each side which means you probably have a 3.6" pulley on your blower right now.
Old May 2, 2007 | 06:27 PM
you are pretty darn close.. I called ATI today... I am supposed to have a 3.70.. I ordered a 3.40 w/a shorter belt to up some boost
Old May 3, 2007 | 08:22 AM
KS91Z28's Avatar
That's funny. When I first typed out that reply I had " 3.6" or 3.7" ", then I went back and deleted 3.7". Are you going to go down and have Ed Wright do some tuning for you or are you doing the tuning yourself? Now you can show them Wichita Mustang boys what an old thirdgen can do, huh.
Old May 3, 2007 | 08:10 PM
Going to Ed Wright on the 18th... Should be interesting !!
BDR
Nov 7, 2015 03:05 PM
Nervous2
Oct 8, 2015 10:53 PM
evilstuie
Sep 24, 2015 02:31 AM
Linson
Sep 21, 2015 01:08 PM
m00n420
Sep 11, 2015 02:39 PM
