pistons?
Old May 3, 2007 | 04:19 PM
355tpiz's Avatar
Car: 1987 iroc z28
Engine: 355 vortec HSR
Axle/Gears: 3.45
pistons?
Is there any way to tell what kind of pistons are in my 355 shortblock? I bought the engine awhile ago and the seller dident know anything about it. But everything looks real fresh, i would like to know before i consider nitrous
Old May 3, 2007 | 05:01 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Re: pistons?
is they're any part number on the top of the pistons?
Old May 3, 2007 | 05:16 PM
355tpiz's Avatar
Car: 1987 iroc z28
Axle/Gears: 3.45
Re: pistons?
theres no part number that i can see
Old May 3, 2007 | 05:49 PM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
Re: pistons?
maybe you can see a number on the inside of the pistons from the botom, if not pictures or removal of them are needed.
Old May 3, 2007 | 07:11 PM
Re: pistons?
he doesn't have a receit for the machine work does he?
Old May 3, 2007 | 07:52 PM
355tpiz's Avatar
Car: 1987 iroc z28
Axle/Gears: 3.45
Re: pistons?
I found a number inside the skirt of the piston it reads H
3497 99
Old May 3, 2007 | 08:25 PM
355tpiz's Avatar
Car: 1987 iroc z28
Axle/Gears: 3.45
Re: pistons?
I think i found them
http://www.kb-silvolite.com/spistons...tails&S_id=255
so are these decent pistons ?
Old May 3, 2007 | 08:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: pistons?
They're budget hypereutectic rebuilder pistons. You could put a modest amount of spray on them if you were careful.
Old May 3, 2007 | 08:29 PM
Car: 91 formula ws6
Re: pistons?
id say 100 shot max, and dont do it to often . they aint no forged pistons!
Old May 3, 2007 | 09:29 PM
355tpiz's Avatar
Car: 1987 iroc z28
Axle/Gears: 3.45
Re: pistons?
So id probably be better off to not run nitrous.
Old May 3, 2007 | 10:01 PM
DIGGLER's Avatar
Re: pistons?
they arent that bad.... you can run a 150 shot on them fairly safely. well, as long as you keep it tuned right.
Old May 4, 2007 | 03:30 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: pistons?
150 max.. make sure it has nice ring gaps and the tune is spot on.. too rich or too lean will destroy those pistons..
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
