Paxton SN89 Supercharge Questions Just Purchased!
Old May 4, 2007 | 05:24 PM
joephis2002's Avatar
Just purchased a factory rebuilt SN89 Supercharger kit for my 89 iroc. It is the complete kit with oil cooler for my tpi setup. Have a few questions tho...right now here is the mods I have done:
  • stock 350 lower
  • aluminum vette heads 2.02 ports
  • cam
  • some upper intake porting (airfoil, plenum work)
  • fuel pressure reg. / ignition coil
  • full edelbrock exhaust
My question is will I need to do anything else to the car? Chip? Fuel injectors? Fuel rails? ANYTHING? Car has only 57k on it so low end is still strong...any help would be GREAT! And any advice would also be wonderful! Thanks guys!
Old May 5, 2007 | 02:39 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: Paxton SN89 Supercharge Questions Just Purchased!
Fuel Injectors, and fuel pump, once its installed should get it tuned. Maybe an MSD box with boost retard, and a set of plugs. Although you should be able to run decent boost with the aluminum heads. What are the specs on the cam you're running?
Old May 5, 2007 | 09:48 AM
Any idea on what size injectors/pump? And for the cam its a comp cam specs i have listed are:
  • gross valve lift .449 intake .456 exhaust
  • duration @ .050 212 intake 218 exhaust
not sure what else you would need. and thank you for the already given info...
Old May 6, 2007 | 05:09 AM
Car: 91 z28
30# injectors and a walbro 255lph call it a day., i would suggest some more lift on that cam and maybe some more duration, make sure the LSA is around 112-114.
Old May 6, 2007 | 06:25 PM
vwdave's Avatar
I would be worried with the vette heads with the 58cc chambers and boosting it. Your compression is probably somewhere in the 9.75-10.0 range.
Good luck though.
Old May 14, 2007 | 10:58 PM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
according to the tech at paxton you can run up to 6psi at 10.5:1 cr. and not have any problems as long as your retarding your timming..
Old Nov 7, 2013 | 01:12 AM
jumpman's Avatar
Car: 87 iroc z
Engine: 305 tpi
Transmission: 5 spd
hello,im planning to install a Paxton sn89 charger on my 87 iroc 305.i have a performance chip and was wondering should I take it out so I don't cause any problems.also what fuel injectors lbs do I need?
Old Nov 7, 2013 | 04:14 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
You're probably better off starting your own thread instead of pulling up one of these old ones but least your using the search function
Since you have MAF and you're a 305, you might be able to run it as is. Take the chip out and lower the base timing some.
toronto formula
Nov 10, 2015 06:17 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
