Turbo
Old May 20, 2007 | 05:06 PM
MattSloc's Avatar
Car: 1986 Camaro Iroc-z
Transmission: 700r4 w/ custom shift kit
Turbo
How much would i be looking at for a turbo charger on my 86 iroc with a 305 TPI
Old May 22, 2007 | 09:19 PM
rob_m's Avatar
Re: Turbo
You've left alot of factors out, what are your performance goals? What our your fab resources. Can you do alot of it yourself. I've heard guys claim over at turbomustangs that they've put together junkyard systems for around $1200, but I'd consider that the bargain basement end. Consider that you'll have hundred$ in mods to the fuel system alone.
Old May 22, 2007 | 09:36 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Re: Turbo
Ill sell ya my setup for 1500 with meth setup and boost gauge.
lol
Old May 22, 2007 | 10:06 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
Re: Turbo
i sense sarcasm, but if your by any chance serious, please email me or PM, i am very ineterested, as i am about to purchase a large order or turbo parts and accessories and have cash in hand. thank you.
kburch5647@yahoo.com
Old May 23, 2007 | 10:53 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Turbo
Here is a rough list for the latest plow truck single turbo setup:
$230 64mm / .76 A/R Holset turbo (new take off)
$200 24x12x4.5 Griffin intercooler and 1/8" alum plate for end tanks,argon,rod
$150 Mcmaster Carr 1.6 ID pipes,elbows, 3/8" steel for header flange at head
$280 Ford fuel injectors (8 new)
$200 Silicone couplers & T-bolt clamps
$100 cold side plumbing
$50 S/S drain line & fittings
$10 oil inlet line
$150 exhaust pipes,flanges,T-bolt clamps
$50 big air filter K&N
$60 2-bar MAP sensor
$15 exh. manifold gaskets
$15 exh. manifold bolts (1" long ARP)
$00 DIY PROM tuning (or prom burner $50-$150)
optional
$70 VW compressor bypass valve, hose, pipes
$250 Water/Meth injection
Old May 23, 2007 | 11:08 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Re: Turbo
The first setup...about $1600. Could that kit have been cheaper, YES
$000 No intercooler
$10 Stock TPI manifolds with 1/4" welded to them (steel from junkyard,etc)
$60 stock fuel injectors with nitrous solenoid and jet
$80 rubber couplers, screw clamps
$50 No intercooler(less pipes), cold side plumbing, junkyard car exhaust
$50 S/S drain line & fittings (don't scimp here)
$10 oil inlet line
$100 exhaust pipes from junkyard,flanges,T-bolt clamps
$00 stock air filter
$20 Diesel 3-bar MAP sensor along with a stock 1-bar sensor (code mods)
$10 exh. manifold gaskets
$00 stock TPI bolts
* Requires a day at the junkyard and steel recycle place
TOTAL: $600-$700
Old May 25, 2007 | 10:00 PM
rob_m's Avatar
Re: Turbo
junkclctr, not to be argumentative, but aren't you neglecting fuel delivery upgrades? Even if his stock pump and lines will feed it (unlikely unless his goals are really mild) his FPR is not boost ref'd. He'd at least need a different fuel pressure regulator, wouldn't he?
Old May 25, 2007 | 10:34 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Re: Turbo
Questions are good. The first setup used bigger Ford injectors. That is actually how I am setting it up (Ford 42#/hr). The second cheap setup used a nitrous fuel solenoid and injector.
EDIT: The stock lines are fine up to a point. I would go with a bigger fuel pump over stock for 400+ HP.
Old May 25, 2007 | 11:10 PM
rob_m's Avatar
Re: Turbo
Ahh, I wondered about the nitrous solenoid! I wondered why you wanted him to run nitrous. You were using it for fuel enrichment!? I missed your point there.........
Don't you still need boost ref. regulator for a turbo app? That was my understanding.
Old May 26, 2007 | 01:35 PM
MattODoom's Avatar
Car: '88 G T/A
Re: Turbo
If you're talking about a FMU, you don't need one. That's one way to do it but you dont have to and preferably with a stock pump, shouldn't.
The stock regulator is vac/boost referenced. For every PSI of boost it will raise fuel pressure by 1 psi, which cancels out with the air pressure in the manifold that the fuel is spraying against. So in the end it will just maintain your stock pressure.
Old May 26, 2007 | 03:36 PM
rob_m's Avatar
Thanks for the info, matt
I never knew that stock non turbo'd cars came with boost ref'd FPR's.
Old May 26, 2007 | 04:10 PM
MattODoom's Avatar
Car: '88 G T/A
Re: Thanks for the info, matt
TPI cars use a vacuum referenced fuel regulator for less pressure at idle. So when boost hits the diaphragm its just a 1:1 increase, which as I said has no effect because of the pressure differential remains the same.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
