most N2O power getting fuel from fuel rail
Old Jun 20, 2007 | 09:18 PM
turbotater's Avatar
using a 255 pump and stock lines how much
power increase has someone made getting the fuel
from the fuel rail ??? BTW motor made 320 rwhp
no bottle.
Old Jun 22, 2007 | 10:29 PM
pairtoe's Avatar
Re: most N2O power getting fuel from fuel rail
are you asking how big of a shot has some one ran using the fuel rail? or how big of a shot can you run without using the fuel rail?
Old Jun 22, 2007 | 10:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
depends on fuel pressure, keep running more and more until the fuel pressure safety switch shuts it off. IIRC around a 175 shot, I'd have a dedicated fuel system for sure though.
Old Jun 23, 2007 | 07:23 PM
turbotater's Avatar
i assume you mean a fuel pressure switch
after the fuel rail before the solenoid ...
ain't got one ...
4 fogger nozzles w/ .018 F & .030 N jets
Old Jun 28, 2007 | 09:24 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I have the 5151 kit pulling fuel from the rail and my fuel pressure doesn't drop on a 175 shot. I also have the hot wire kit. With as much as I've had to jet down the fuel side to stay above 10:1 afr I wouldn't think fuel delivery would be a problem with the stock rails. I'm going to spray the 225 shot soon(.083 nitrous jet?), I'll let you know what happens.
Brcharrelson
Aug 26, 2015 07:47 PM
mdtoren
Aug 23, 2015 12:52 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
AkDrifted
Aug 17, 2015 07:45 PM
mdtoren
Aug 16, 2015 05:45 PM
