dimentions of your intercoolers on turbo'd camaro's
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Just wondering . I am seeing alot on ebay right now ...kinda trying to figure out what would be easiest to fit in there . I want a 3" in/out right ? considering my other intake pipeing is all 3" ..
Other things that I am wondering about ....
1. Why are some intercoolers $85.00 while I had a guy offer me a used ATI intercooler for $900.00 ???? Like how much better can it really be ? It was even smaller .
2. Haveing 3" intake pipeing ...should I get the 2.75" pipeing , as to create a bit of an increase in preasure ( going big to small ....) ? Or should I be aiming for all 3" in/out .
3. I am trying to get an idea of the dimensions for the size I should be looking for .... I see stuff all the way up to 30" wide ... What would be the best size for me .... as to just put some tabs on the end and mount it easilly .
4. I see different styles of intercooler ...like plate , tube , etc . Whats the differances ... whats better ?
5. The one I was looking at is like 85 dollars .... it is rated at 500 hp . as a target I am shooting for 650 hp ( dowwwwwn the road when i can get the parts to make and , handle the boost ...like aluminum heads ..beterr rearend ...tranny , etc.) Would this be a bad buy for me ? It's only 85 dollars
thanx a bunch all for checking this out
Dan
Dan
Car: 92 Z28
Engine: Boosted LSX
Re: dimentions of your intercoolers on turbo'd camaro's
I had a ebay one. Just never finished the project yet.
Alot of the 4thgen buys and Turbo truck guys like the cheap ebay one.
They are Bar & Plate.
http://www.cecoatings.com/images/Car...rboMotor/FMIC/
Mine was a 3inch core. like this one
http://cgi.ebay.com/ebaymotors/3-COR...QQcmdZViewItem
They have cheap 4inch core ones now.
http://cgi.ebay.com/ebaymotors/FMIC-...QQcmdZViewItem
You should be fine with one of these.
Car: 1989 IROC-Z
Hay I REALLLLLY apreciate the pics and advice . Seeig how I am only hitting a max of 650 hp ( if that really) ..I should go wiht the middle one.
Now I gotta ask ... I figured I had enough room in there to slide it up in and mount. You really think it nessesary to tak the nose off to mount it ? I figured there was enough room to slid it up ther eand just make some L brackets
Car: 1989 IROC-Z
sweet to know that . My dad though we may have to take it off....it looked like there was room to do it
Car: 92 Z28
Engine: Boosted LSX
You might have to remove alot of plastic and even the impact bar.
Or you could do it like this...
In front of the radiator.
http://www.cecoatings.com/images/oth.../P81701582.JPG
http://www.cecoatings.com/images/oth.../P81701571.JPG
http://www.cecoatings.com/images/oth...%20bottom1.jpg
http://www.cecoatings.com/images/oth...er%20exit2.jpg
http://www.cecoatings.com/images/oth...%20intake3.jpg
Car: 1989 IROC-Z
I already have alot fo that plastic gone from when i put my home made ducting in there ( which will have to go )
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Car: 1989 IROC-Z
Hay thanx for that alll. I am not up on engine calcs really... just don't know where to look for them ( googleing I go I guess
I never knew there could be that much of a differance in interocooler quality . Thanx for the tips on that .
)I never knew there could be that much of a differance in interocooler quality . Thanx for the tips on that .
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I got to side with Skulte on this one.
Intercooler sizing and efficiency is about as complicated as turbo sizing and compressor maps.(not that complicated actually once u figure out how to read the maps)
Most of the time u get what u pay for as well.
Shop around and learn what u need to find the proper one.
Also frequent the buick boards :-) We cut and hack everything out there :-)
later
Jeremy
later
Jeremy
Car: 1989 IROC-Z
yeah I figured i'd get this one ... it " looks" good. I figure haveing a rateign of 1000 hp .... it's uneffeciancy's ( sp :P ) will make it good enough for a 650 hp setup
No? also it says 0.2- 0.5 psi drop over at 15psi ...
thanx I will check out the Buick boards ..got one in mind ?
No? also it says 0.2- 0.5 psi drop over at 15psi ... thanx I will check out the Buick boards ..got one in mind ?
Car: 92 Z28
Engine: Boosted LSX
Terrell351
Jun 13, 2021 01:13 PM
toronto formula
Nov 10, 2015 06:17 AM
