HSR nitrous??
Old Sep 21, 2007 | 04:27 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
HSR nitrous??
Wondering what HSR guys are running for nitrous? what brand? what kit and such
Old Sep 21, 2007 | 04:35 PM
jjvette's Avatar
Car: 89 vette
Transmission: a4
Re: HSR nitrous??
NX GM EFI Race kit adjustable from100-250rwhp.
383 HSR
Old Sep 23, 2007 | 06:24 PM
Car: 92 Camaro
Axle/Gears: S60 373
Re: HSR nitrous??
hopefully my tranny can take that 100 shot of laughing gas.... has anybody used the NOS brand? i know NOS is cheaper but trying to get a variety of brands and experiences but NX is at top of list as of right now
Old Sep 25, 2007 | 10:53 AM
Car: 92 Camaro
Axle/Gears: S60 373
Re: HSR nitrous??
nobody else?
Old Oct 2, 2007 | 05:51 PM
Sprayed92's Avatar
Car: 92 Formula
Engine: 383 248/256 cam
Transmission: 700r4 3500 stall
Axle/Gears: 9" 3.89 gears detroit locker
Re: HSR nitrous??
I've got the tpi plate kit it works very well. car should run consistant low 12's on the spray it ran 12.3@109 with the tpi on it. Nos Brand
Old Oct 2, 2007 | 06:09 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: HSR nitrous??
i just wanna know alittle about the distribution with a single fogger nozzle. I have heard HSR has alittle distribution problems. Where do you mount it for best distribution? should it be infront of the TB or on the plenum?
I want to run a direct port system just to be sure i have even distribution. Although plate systems seem to do well too.
Old Oct 2, 2007 | 11:49 PM
Sprayed92's Avatar
Car: 92 Formula
Re: HSR nitrous??
yeah they do have a little dist. prob they won't flow enough for a 250 shot I do know that for a fact.
for you orr a plate would work good it works well on mine.
Old Oct 3, 2007 | 02:02 PM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Re: HSR nitrous??
I'm running a Nitrous Express 2 stage kit, 150 on the first stage, 100 on the second, haven't had any problems.
Old Oct 3, 2007 | 06:00 PM
jjvette's Avatar
Car: 89 vette
Transmission: a4
Re: HSR nitrous??
Hmmm I haven't dynod it yet but its advertised for 250 @ the wheels.
My kit is the EFI Race kit with the single nozzle in front of the t.b.. I don't know if that matters or not. The solenoids are rather large!
John
Old Oct 3, 2007 | 07:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: HSR nitrous??
why cant it handle a 250 shot? is that jsut for single nozzle foggers or plates? what about a direct port 200-300 shot?
Old Oct 3, 2007 | 09:19 PM
Sprayed92's Avatar
Car: 92 Formula
Re: HSR nitrous??
that was a single nozzle haven't tried a plate yet, that car loaded up and had a nasty backfire and blew the mass air off the car.
Old Oct 4, 2007 | 04:18 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: HSR nitrous??
I hear the NOS plate has distribution problems on the TPI intake with it shooting nitrous past the first 2 runners. The HSR would seem to be worse off with this issue seeing as the runners are closer and straight down. Anyone have experience with a plate on these?
Old Oct 7, 2007 | 02:48 PM
Sprayed92's Avatar
Car: 92 Formula
Re: HSR nitrous??
Yeah my car uses the NOS #5151 plate kit on it and I have the hsr on my car and my plugs all look the same no lean ones anywhere. Still spraying a 150 shot stock bottom end stock motor stock tranny too hell I'm even spraying thru the shifts
86z89iroc
Oct 5, 2015 01:04 PM
mike22115
Sep 28, 2015 04:49 AM
BBSDesigns
Sep 22, 2015 03:08 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
