Hidden Nitrous system.
Old Oct 23, 2007 | 10:11 PM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
Anyone have pics of hidden nitrous system. Bottle can only realy go in passenger rear panel but what about under the hood. Pics would be great.Thanks guys
Old Oct 23, 2007 | 10:36 PM
EvilCartman's Avatar
Car: '82 Z28
Re: Hidden Nitrous system.
Well if it's hidden, you're not really going to see much are you
Old Oct 23, 2007 | 11:39 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I've thought of a 'sneaky pete' setup.. wouldn't be overly difficult.
Old Oct 24, 2007 | 10:58 AM
2fast4u92z's Avatar
I was thinking of mounting and runing the line under the Super Ram right where the EGR block off plate is. Bottle powercoated black and mounted in the spare tire area in the trunk. I would want a rpm window switch.
Just wanted to see if anyone had some better ideas. Now I just need to see if the drivetrain can handle this.
Old Oct 24, 2007 | 02:14 PM
jed5161's Avatar
Car: 88 Trans Am GTA
Engine: 383 Lingenfelter/AFR 670 hp
Transmission: 700r4 3500 stall
Axle/Gears: 3.90 9 inch
im drilling into the back of the block above the bell housing and running hard lines to the intake ports. havent decided yet if it'd be a good idea to keep the solenoids in the motor or not. i'm going to have the max hp pill size in the nozzles and regulate the hp rated flow by a seperate pill block somewhere by the trans. at least thats the plan so far haha
Old Oct 24, 2007 | 02:45 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
anyone who knows how to mount hidden systems would be keeping their mouth shut Also I know of 4 places in a thirdgen to put a bottle that has never been found while racing . But of course I wouldn't run nitrous cough cough
Old Oct 24, 2007 | 09:45 PM
2fast4u92z's Avatar
I had friend runing a bottle (not a 10lb) in the passenger door. with the door panel on you can't tell. A small rubber gasket on the under side of the was a way to fill the bottle or to turn it on. worked for years tell he was caught.
I like the idea of the holes above the bellhousing, but would run the solenoids like inside the car right on a 90* fitting that went throught the firewall then all you need is a small braided house from firewall to block. with flex line from the block fitting and the hard line blocks the intake could be removed.
Old Oct 24, 2007 | 10:09 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
This might sound like a stupid idea. I just thought it up reading thist thread. But what if you could customize the gas tank(chop it) then where you chopped it put the bottle in there make it look like a gas tank without anyone even noticing!!
I'm so glad I have an overactive imagination makes me want to do it myself
Old Oct 25, 2007 | 12:07 AM
2fast4u92z's Avatar
that is crazy but I did know a guy that had a fuel cell under the car that had a area to mount a big bottle seperate from fuel. And bottles come in so many sizes I could mount a few under the rear spears in the huge whole from fender to sheet metal that holds the speakers
Old Oct 25, 2007 | 02:19 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
https://www.thirdgen.org/forums/powe...er-plenum.html
Some pictures and ideas there
Old Oct 27, 2007 | 10:34 PM
DPSJosh's Avatar
Car: 1987 Trans Am
Engine: Forged 383 with Brodix Heads
Transmission: Pro-Built TH400
Axle/Gears: 9-Bolt 4.11s with Posi
Heres some bottle mounting places i've been thinking about...
1. Get rid of your ac/heat box and mount it inside/under the dash.
2. Go to a fuel cell and have a box under the car for the bottle.
3. In the spare tire/t-top well in the trunk, then put some kind of removable plate over it.
4. Small bottle could be mounted in the door.
5. Cut a plastic fuel cell in half, take out the foam, put a 5lb motorcycle bottle in it, cover the nitrous line with wireloom or something.
These are just random spots off the top of my head, the all have problems, but hey, maybe you can make one work.
Old Oct 28, 2007 | 01:07 PM
2fast4u92z's Avatar
I am going to have my chassis guy make up a aluminum mount that will bolt in without to much change to the car and hold the bottle on a 45* angle in the spare tire area.
I don't need hidden like in cheating in races but like in show car can see in in the engine comparment.
So I was going to end up using my TB plate. A guy at the shop said if I used hard line to the plate and mount the solenoids under the intake. Then slide ruber tube over the hardlines and a ruber elbow. I bet 90% of people will have no idea.
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
meeklay812
Oct 1, 2015 03:46 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
