Methanol Injection Question
Old Nov 9, 2007 | 11:20 PM
blue82_z28's Avatar
Car: 1982 Camaro Z28 w/ RS groundfx
Transmission: Tranzparts 700r4
Axle/Gears: 3.23's
Okay, in a blowthru turbo carb application, would you use an under carburetor adapter for the injection or would you just run the lines after the b.o.v. but before the carb??
Old Nov 10, 2007 | 07:14 AM
blown3rdgen's Avatar
Re: Methanol Injection Question
I use a single nozzle from snow performance right after the supercharger
Matt
Old Nov 12, 2007 | 12:37 PM
whiteghost7's Avatar
Car: 92rs
If you have a BOV run your nozzle after the BOV to limit the likelyhood of invisible methanol flame underhood explosions. Its not a common thing but it does happen. I've found that 6"-a foot before the throttle body works good with most applications.
Old Nov 12, 2007 | 12:56 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
x2
I have mine mounted right before the TB.
Old Nov 13, 2007 | 04:36 PM
blue82_z28's Avatar
Axle/Gears: 3.23's
alright thanks, and wow that engine bay look clean as hell. lol.
Old Nov 15, 2007 | 10:32 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I run a 5 GPH mcmaster-carr.com misting nozzle about 4-6" in front of the stock TPI throttle body. It turns on partially at 4 PSI and full on at 14 PSI of boost. It works well with a 50/50 water/alky mix.
Cleotiz
Jan 6, 2018 08:56 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
toronto formula
Nov 10, 2015 06:17 AM
z28addict8490
Sep 5, 2015 03:56 PM
redmaroz
Aug 16, 2015 11:40 PM
