Nitrous bottle mounting with Battery relocated
Old Nov 10, 2007 | 03:14 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
I was wondering if anyone has relocated there battery to the trunk with there nitrous bottle mounted in the trunk as well. Id like to see some pictures of people who have done it. I have relocated my battery to the trunk and I want to also mount the bottle in the trunk as well but just a little unsure of how to make everything fit.
Old Nov 11, 2007 | 05:29 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: Nitrous bottle mounting with Battery relocated
mine is in the spare tire compartment, the 860 bracket for 4th gens will work with just 1 mod.
you just have to drill a hole in the floor right where this bolt goes, i would recommend moving the bottle mount bolt holes up about 1.5 inches forward to get a better grip on the bottle, though it doesnt move in the stock mounting holes.
Old Nov 11, 2007 | 08:28 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
What company makes that bracket and can I get it from summit?
Old Nov 11, 2007 | 08:41 AM
Car: 91 z28
860 performance and No. I got it from nitro daves but he doesnt carry it anymore.
Old Nov 11, 2007 | 10:09 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
found it. http://www.nitrousoutlet.com/catalog...product_id=963
Old Nov 11, 2007 | 01:01 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
I like this bracket but Im not thrilled about loosing my spare tire. If I did not want to occasional drive the car on the street I would have no problem getting rid of the spare tire.
Old Nov 11, 2007 | 01:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
put the bottle on the hump of the driveshaft tunnel then it'll go in between the rear seat bottoms.
Old Nov 11, 2007 | 02:35 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Ive seen that done in a 4th gen not my favorite option. I like the idea of the bottle being semi hidden in the well area. I took a second look at the fit of the bottle next to the battery box. All I need is a few inches to clear the bottle valve and the battery. So Im decieded to give something a try to make it fit. Im gonna take some 2" x 2" x 1/8" think steel square tubing I have laying around and cut two peices and use that as a spacer between the floor and the bottle brackets. The bottle valve is then high enough to clear the battery box and with enough room to run the blow off pipe and supply hose. I will take a couple pictures and see what you guys think. If this dosent work out I may just buy the bracket to mount it in the spare tire area.
Old Nov 11, 2007 | 02:39 PM
xpndbl3's Avatar
Car: 1984 Z28
you said you didn't want to lose the spare tire area, so i gave another option and now you're just going to put it in the spare tire well? o ok. The bottle should be facing forward and I don't see that being possible in the trunk storage well compared to the spare tire well or the driveshaft tunnel.
Old Nov 11, 2007 | 02:50 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Yes thank you for the idea. I dont want to loose the spare tire but the mount in a nice idea. I realize that the bottle being mounted with the valve facing foward is optimal but the bottle can mounted side ways as long as the bottle in angled so the siphon tube is at a 45 degree angle to keep it in the liquid on acceleration. I will take a picture of the idea I just though of and I will post it to see what you guys think. If you guys think it sucks. I will try another option.
83 Crossfire TA
Jan 3, 2016 01:26 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
andy74
Sep 3, 2015 08:41 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
