As i creep closer to getting this project started
Old Dec 3, 2007 | 09:57 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I have come up with my main plan. I plan to get a spare l98 from a friend, get it machined and done to a 383, then put new heads on it which ones I am unsure of. then keep the TPI intake cuz I love the look and finish it off with a s/c. My problem is picking the right heads cam and I can figure out a s/c after that. Im goin for a solid 500-600hp on the s/c. And no its gonna be a drive to the store and drag strip car really. Anyways i got all my other stuff underway for this just tryin to figure out the rest. Should i just get the l98 heads ported? or will it not be big enough? Maybe some ls2 heads?
Old Dec 3, 2007 | 11:03 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: As i creep closer to getting this project started
ls2 heads aren't from the same motor generation, they won't work. I'd imagine a quality blower and some AFR heads or similar would get the job done easily.
Old Dec 4, 2007 | 06:12 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Yep, what he said! LS2 heads are different. I would reccomend some AFR Eliminator 195's, and something like a D1SC or F1. You might also want to invest in an aftermarket tpi base and runners or upgrade to something like a HSR.
EDIT: if you're looking to do alot of racing you might want to invest in an aftermarket engine management, like the holley commander. It's about $800 and will plug right in.
Old Dec 4, 2007 | 06:17 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Depemding what you are looking for budget wise, HRS makes some decent heads price wise, but if you are looking for aluminum you will of course save weight but shell out more cash.
Old Dec 4, 2007 | 02:58 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Well. I will do the heads. And yes i will be buying upgraded TPI intake parts for it. I just like the look of the intake. That management system sounds like a good idea. when you mean plug in, how much plugging in is there?
Also what would be a good cam to run along with?
Old Dec 4, 2007 | 11:40 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
If you want 500-600HP then I wouldn't bother with heads. Maybe just port the stock heads. Size the S/C properly and you should be fine for that HP level.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
