Is this a good setup from eBay
Old Dec 26, 2007 | 11:22 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Check This out and tell me what u think. Is this worth it or not?
Old Dec 27, 2007 | 12:53 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Is this a good setup from eBay
yes definitely worth it.....what am i supposed to be seeing?
Old Dec 27, 2007 | 01:10 AM
Engine: 350/350/LS1
The twin turbo setup
Old Dec 27, 2007 | 01:44 AM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
You might want to add a link or something!
Old Dec 27, 2007 | 02:14 AM
Engine: 350/350/LS1
I am very sorry I thought I added it it
http://cgi.ebay.com/ebaymotors/ws/eB...TODAY.m238.lVI
Old Dec 27, 2007 | 02:34 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
the turbos looks like its cheaply made.
Old Dec 27, 2007 | 08:44 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
its your standard 'cheap' kit. reinforce the headers and it may work out for ya. turbos are probably cheapies also but they dont look like the ones that were glued together. give it a shot and post results.
Old Dec 27, 2007 | 09:02 PM
Engine: 350/350/LS1
I'm not going to add this or any power adders for the simple reason I don't want to build up the block. The only adder is probably going to be a cold air intake kit.
Old Dec 27, 2007 | 09:34 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
cold air intake on that car = +/- 5hp.
Old Dec 27, 2007 | 09:36 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
save your $, its not worth it.
Old Dec 27, 2007 | 10:07 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Looks like the same kit as this thread:https://www.thirdgen.org/forums/powe...it-bullet.html
Maybe you could ask him if he likes the kit.
Like BDR said, you would be better off saving for a power adder than buying a cold air kit.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
TheExaminer
Aug 25, 2015 07:34 PM
the_nikfive
Aug 11, 2015 02:46 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
