Tired old 305 VS. the 200 shot
Old Feb 29, 2008 | 11:08 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
So we're going to go through with upjetting a 1985 305 TPI car to a 200 shot here soon. The car's been surviving on a combination of a .069, .035 jet run after run so we've gotta do something to get it to torch. We'll be monitoring it closely and attempting to get it to live as long as possible, this isn't some "lets blow it up to be hicks" thing. I'll hopefully get some videos of the car running at the track barring it melting before then.
Old Mar 7, 2008 | 12:48 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Tired old 305 VS. the 200 shot
hopefully it makes it all the way down the track safely.
Old Mar 7, 2008 | 03:34 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Is this a EFI port system then?
Old Mar 7, 2008 | 08:01 PM
Basic wet nozzle system, old abused 305, 0 degrees base angle timing, car has 3.73 posi rear and shift kit in the trans plus a ton of free mods done to the 305. It's been the nitrous mule, the kid who owns it has a new engine and we've been letting friends who've never ran spray drive it to get used to it. This went fine until someone decided to spray the 125 shot immediatly out of the hole which resulted in a backfire that broke one of the maf wires . Next plan is to purchase a mAF with a warranty As for making it down the track safe, I'm sure it will. If anything breaks I put money on it it will either be from an intake backfire, or cracked piston. I highly doubt it will blow anything up bad enough to scatter fluids on the track or hurt the driver.
Old Mar 7, 2008 | 09:48 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
always be careful, you never know....
Old Mar 10, 2008 | 10:59 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
my mechanic did the same with a 89 iroc, put a 250 shot fogger system on it. at the same time he was building a big block for the car. he said the car was bone stock, just uncorked the exhaust thats it. he then walked his buddy's 11 sec car.. it never blew. gave it to a guy to put in a pickup truck. its still running about 5yrs later. i dont think its been sprayed since though.
Old Mar 10, 2008 | 12:08 PM
I know we're going to end up with some REALLY funky fuel distribution on this kit but I think it'll be better than my plate setup because it's spraying in front of the throttle body blades giving the nitrous more time to disperse. We plan to run a pair of nozzles and possibly do this as a 2 stage, that will reduce the load on the car and give it alot less chance of backfiring through the intake from being sprayed to low again.
Old Mar 10, 2008 | 12:26 PM
awilson82's Avatar
Car: '82 Camaro Z28
Engine: 383
Axle/Gears: 3.73 with powetrax
Gotta love the spray!
Old Mar 10, 2008 | 04:50 PM
DIGGLER's Avatar
window switch.
Old Mar 10, 2008 | 05:00 PM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
I put a 150 shot on my 305 TBI it went 7.88 in the 8th. Ran a 12.49 running out of gear in the 1/4 should of went 12.29 atleast.
Old Mar 10, 2008 | 09:31 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
my old 305 with a 3500 stall was sprayed right off the tree. 150 shot was good for 11.60s all day long.
Old Mar 10, 2008 | 10:30 PM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
What kind of exhaust setup do you have in there? It sounds good for a 305 TBI !!
Old Mar 11, 2008 | 10:42 AM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
Mac Shortty headers and off road y pipe, dmh elec. cut out, flowmaster catback.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
LT1Formula
Nov 16, 2015 01:13 PM
