Twin Turbo TPI Cam Suggestions
Old Mar 5, 2008 | 07:02 PM
camaro_freak39's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 (334 SBC coming soon)
Transmission: 700R4 (soon to be replaced by T56)
Axle/Gears: 3.23 (soon to be 3.73 posi)
thinking about doing a twin turbo tpi. wondering what cam i should use. would prefer off the shelf if possible. any help is appreciated
Old Mar 6, 2008 | 10:51 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Twin Turbo TPI Cam Suggestions
Combo specs please. Engine, turbo's, gearing, car usage, desired HP output, etc etc.
Old Mar 6, 2008 | 01:09 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Originally Posted by camaro_freak39
thinkin bout doin a twin turbo tpi. wonderin wut cam i should use. would prefer off the shelf if possible. any help is appreciated
Why the missing 'g' on your words? A nice turbo cam should make some power in that thing.
Old Mar 6, 2008 | 03:46 PM
Car: 1991 Camaro RS
Engine: 355 SBC
Turbos: .50AR Trim T3/4 V Band
Gearing: 3.73 rear, stock LT1 T56 trans
Usage: Street/Strip (mostly street)
Desired HP: 650-700
Hydraulic Roller cam desired.
Old Mar 7, 2008 | 12:45 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Check out ststurbo.com a lot of people on this board have them and love them, look them up.
Old Mar 8, 2008 | 05:28 AM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
If we're talking about ebay turbos on this motor, you're going to need to keep a mild cam, and low compression (~8.5:1) with around 20psi boost to beat the TPI intake. maybe a turbo designated cam with no more than 216duration @.050" lift. with too high a powerband, you'll be spinning the turbos way out of efficiency at flow rates needed for anywhere near the desired power output. I actually reccommend the restrictive TPI intake for these turbos because they are way more efficient at relatively higher boost levels for given flow rates. I've logged IAT's to estimate efficiency as well as measured the compressor wheel and compared it to a garrett TO4E 46 trim compressor flow map.
Old Mar 8, 2008 | 06:18 AM
Car: 1991 Camaro RS
I've got a MiniRam on it, so my powerband is up higher than the normal TPI intake.
Old Mar 8, 2008 | 08:44 AM
Well if you're planning to use ebay turbos, i'd shoot for a little lower hp goal. maybe 550hp (about 12-14psi boost).
Old Mar 8, 2008 | 08:52 AM
Car: 1991 Camaro RS
I'm using a pair of Garrett turbos from ATP Turbo, here is the link
http://www.atpturbo.com/Merchant2/me...egory_Code=TBN
They will be mounted on BBS headers.
Old Mar 13, 2008 | 01:16 PM
shocker89bird's Avatar
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
Good rule of thumb for a turbo motor especially a sbc is to run a single pattern cam. Split profiles can work effectively if dialed in perfectly but a single pattern with at least 114 lobe seperation is good. If you have the parts to flow to high rpm don't be afraid to run alot of duration.
Old Mar 14, 2008 | 01:29 PM
junkcltr's Avatar
Engine: 3xx ci tubo
That is just a general "rule of thumb". He would be better off looking at the cam card for the timing events.
Here is a another rule of thumb...one that I prefer. Set the intake duration for the RPM range. Set the exhaust duration and LSA for the exhaust on the vehicle. More restrictive exhaust requires less overlap. So for a big turbine pick an exhaust duration & LSA like a good flowing NA exhaust. For a little turbine spread the LSA and shorten the duration. Watch LSA for the general HP curve (peaky vs. broad).
Old Mar 14, 2008 | 09:42 PM
83 Crossfire TA's Avatar
Looks like you're doing your best to make it as difficult as possible for someone to give you a real recommendation.
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
drathaar907
Aug 6, 2015 04:20 PM
