stock"ish" TPI 5.7 + right turbo =12.00s???
Old Mar 7, 2008 | 05:30 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
I mean a tune, injectors, turbo, and the rest of the car stock, can this be done on real street tires and 94 pump gas
Old Mar 7, 2008 | 06:16 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Re: stock"ish" TPI 5.7 + right turbo =12.00s???
Absolutely. I believe TurboedTPI has a forged piston/otherwise stock L98 (maybe lower compression than stock though?) with aluminum L98 heads and a BBS turbo system going much faster than 12.0's. You'd want supporting mods such as an upgraded fuel system and a torque converter, but I don't see why it couldn't be done.
Old Mar 7, 2008 | 06:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
well i hit 12.90's n/a with bolt ons L98. I'm sure a turbo would EASILY push me another 100hp and get 12.00's. It be like a 100 hp nitrous shot
Old Dec 18, 2008 | 06:44 AM
TURBOPOWERED68's Avatar
Engine: 231
Transmission: 2004R
Axle/Gears: 12 Bolt with 3.42s
Has this set up been done?
I have been thinking about doing this exact set up.
Old Dec 18, 2008 | 09:19 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
With the parts you listed........yes. Even with a "wrong"-ish turbo you could be in the 12s.
Old Dec 19, 2008 | 11:04 AM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Yes
Old Dec 21, 2008 | 09:43 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
I'm pretty sure '89JYturbo(or something similar) has just about that exact setup, I think he ran lower 12's at about 120mph, that was with a manual transmission and low profile street tires.
Old Dec 23, 2008 | 06:33 PM
UR50SLO's Avatar
Car: 86 Turbo Camaro
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Should be NO problem.... Tuning is going to be the most crital part. Go aftermaret with FAST or Accell ect. Save your self alot of headaches with learning ECM hacking... If you've got time and alot of tuning experience it's ok but stand alone is much better and quicker for boosted engines.
If I can run low 10's on 93octane fuel with a V6 you can do it with 2 more cyl for sure!
~Scott
diana227vegas
Jul 8, 2016 12:27 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
stalkier
Dec 6, 2015 11:25 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
