new turbo setup
Old May 1, 2008 | 09:16 AM
project89's Avatar
new turbo setup
no more factory manifolds and under k member y pipe for me
http://www.youtube.com/watch?v=k_XljEUmCGc
http://www.youtube.com/watch?v=wQJ_EB9LBck
Old May 1, 2008 | 09:19 AM
project89's Avatar
Re: new turbo setup
Old May 1, 2008 | 09:36 AM
mellis09's Avatar
Re: new turbo setup
looks wicked sweet! definately what i plan on doin to my v6
Old May 1, 2008 | 12:15 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: new turbo setup
I like it. Give us some more info on your setup. Did you do all the fabrication yourself? Is there an intercooler up by the radiator? What are your plans for the car?
Old May 1, 2008 | 01:53 PM
project89's Avatar
Re: new turbo setup
yeah i did everything.
its 3.1 8.5-1 cr polished rods lightened crank,std pistons, plasma moly rings, ported heads oversized stainless valves,ported manifold with custom sheetmetal uper plenum (just not pictured in the pics)
the cam is a custom grind 268/272 adv duration int/ex
the current turbo is 51mm .63 t3 hotside its way to small
i will be going with one of these 70mm variants soon though
69mm inducer
91mm exducer
or
70mm inducer
98mm exducer
the first oen would be a t4 hotside with an .84 housing
and the second would be a gt42 with a 1.05 ex housing also t4
car has a front mount intercooler its actually painted black,the one in the car is out of a volvo deisel truck,and is way to small for either of the new turbos. but i have yet to decide on a new ait to air or air to water cooler setup
forgot to add the car is tuned by the means of a megasquirt 1 v2.2 running msnextra
Old May 1, 2008 | 09:12 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: new turbo setup
looks pretty good! A master power t-70 with the .68 housing would do nice, even a 60-1 or 62-1. The t-70 is hard to beat at $585 new, they have taken stock shortblock 5.0's into the 9's
Old May 1, 2008 | 09:35 PM
project89's Avatar
Re: new turbo setup
im sticking with the brand of turbo i started with, xspower the turbo on that motor has over 100k on it and alot of high boost time it has minimal play and never had an issue with it.im on another forum with the guy who runs xspower or works for them i think he owns xspower.great deals on the stuff and i have all the exact measurement sof there stuff.he honors all the warrentys and bends over backwards to help ppl when something dont go right.
the first turbo is the specs on the there t61 model which is a copy of the mp t70 unit
the second ones are the specs of there gt45 unit which is a mp gt45 unit
the supra guys love these things and put down some really big numbers with the t61 stuff and even higher numbers with the gt45 stuff avg hp on the t61 stuff is around 500
Old May 3, 2008 | 12:14 AM
project89's Avatar
Re: new turbo setup
http://www.youtube.com/watch?v=LuaInKgvqsA
the last clip was of about 25 mins ago with the car in full street trim threw a muffler nice and quiet hehe stealth mode
dont know what happened with the sound though it was really low,though i am just figuring out how to use it,hell i finally found the dam zoom button tonight lol
Old May 3, 2008 | 10:35 PM
project89's Avatar
Re: new turbo setup
ANTI LAG AND LAUNCH TEST
ive got a fe wmore clips but no runs, i never got the chance to make a single pass before i broke the car,i knew my fan was slightly rubbing the radiator but figured it would be ok, well i was wrong i ended up getting a leak and couldnt run, ill have a new radiator tom if i get it early enough i will be back at the track in the morning to make some passes if not i will deff me making some passes on tuesday or wensday
Old May 8, 2008 | 01:38 PM
project89's Avatar
Re: new turbo setup
some testing at the track
mid 14 @ 6psi on street tires and letting off right before the 1000ft mark mph shows that it was let off way early.will scan the slip tom afternoon.reason being is not having an upto date spec helmet and rental helmets are only good to 14.0 . going back friday on slicks and with a correct helmet to make some full passes. im predicting 13.8 @ 6psi in full race trim or better once i get her a lil more comfortable in the car i will up the boost and throw the slicks back on it for her
btw its not me driving and i suck at filming specially when ur trying to teach somone how to do the burnout and stage/launch a car at the same time
Old May 8, 2008 | 11:15 PM
83 Crossfire TA's Avatar
Re: new turbo setup
you said that is through a muffler? What exhaust is that?
Sweet setup
Old May 8, 2008 | 11:19 PM
project89's Avatar
Re: new turbo setup
no thats threw an open 3 inch down pipe that exits right were that cat flange would be on a stock ex system.my downpipe will bolt to a stock catback
and thnx man,im prolly gonan go with a borla 3 inch cat back or a magnaflow down the road, right now i use a cherrybomb turbo muffler, that i pull on and off for street use it just dumps out the side before the rear tire i have a vidclip somewere with it on lemme try to dig it out
86Firebird86
Dec 26, 2015 07:21 AM
BDR
Nov 7, 2015 03:05 PM
customblackbird
Oct 1, 2015 04:30 PM
R13_Braz
Sep 18, 2015 05:00 PM
Doobie52
Sep 11, 2015 06:19 PM
