150 shot on a 10.75:1 compression
Old May 1, 2008 | 11:49 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Okay First off, I want to state that I am in the process of buying a ignition box for my car. I was told it will help with the compression ration im going with.
Next I want to know how I can use the ignition box and which one to use on my motor to get it prepped properly for a 150 shot. Im guessing I need to retard timing 3-5* for the shot. I dont want to be having that timing retarded all the time. I know there are ignition boxes that will do that automatically, but I dont know what to look for in it or whose a good brand besides msd.
My dizzy is msd and so are the wires, So i thought i would keep it all the same, but I heard summit is making good stuff at an affordable price.
Please help me out here guys
Old May 2, 2008 | 12:07 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: 150 shot on a 10.75:1 compression
I have this box that I never installed on my car, was installed on another car but never hooked up.
http://www.jegs.com/i/Mallory/650/685/10002/-1
I am thinking about selling it.
Old May 2, 2008 | 12:46 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Will that do what I need with the timing.? I know mallory is a good company, but it is all compliable with the msd crap?
Old May 2, 2008 | 01:12 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
if you have MSD you may want to stick with it to ease in the wiring swap and be uniform by using all one product. MSD and Mallory both have similar ignition box setups but wiring is different...different colors and such but you can mix and match if you compare both wiring diagrams for mallory and msd. But the dizzy should have the same basic outputs as the stock unit which works for both ignition boxes so it may not matter which box you get
I just bought a Mallory 685 and it has a retard function that you can wire into the nitrous setup. It will retard any number of degrees you program it to whenever the nitrous is activated. its activated by 12 volts so you wire that into the nitrous activation switches or w/e. So it only retards whenever the nitrous is activated MSD does have a similar setup...i just dont know which model it is. Browse their website for information on their products to see which units have that feature.
I both companies have a box with that feature built in but they also both have timing retard modules that are seperate from the ignition boxes that you can wire into the ignition box and motor
Old May 2, 2008 | 04:06 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i would be more worried about detonation from high compression and 150shot.. also, rule of thumb is 2* per 50shot..
Old May 2, 2008 | 02:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i was under the impression that being near 11 to 1 doesnt matter with nitrous as long as the timing is retarded enough? I know there are plenty of guys running bigger shots on more compression than that
Just run good timing and colder plugs. Should work ok. I hope to run atleast a 150 shot on my 11 to 1 motor
Old May 2, 2008 | 02:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
It is more detonation prone with high compression. Retard timing, use a cooler plug, and keep a high octane fuel for use with the nitrous! I know if I use a 150HP shot on my 10:1 engine i'll be running 94+ octane fuel in the my nitrous cell, vs the 91 in the gas tank.
Old May 2, 2008 | 02:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
thats what i was planning... possibly race 100 octane in a cell for nitrous and retard the timing an extra 2-3 degrees more than normally recommended. running 93 octane in the gas tank for the motor
but then again, LT1's are 10.5 to 1 and they have run 200 shots just fine with colder plugs and timing retard on regular 93 octane..so maybe it will work ok without the higher octane fuel cell
Old May 5, 2008 | 12:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
LT1's are a completely different animal with the reverse flow cooling. We also can't compare our traditional SBC's to small DOHC engines, whole different ballgame.
FormulasOnly
Jul 23, 2018 08:47 AM
Mirror Image
Oct 29, 2017 09:51 PM
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
JSDaddy189
Sep 26, 2015 03:50 PM
