Water, power adder?
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Water, power adder?
I dont know if this is the correct section, but here it goes.
I began making my own water fuel cell and with the help of some friends of mine that are electrical engineers with a degree in "electronics gurus" we are working on very high efficient water separation system using just materials that can be bought anywhere.
How many of you are doing this kind of stuff?
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: Water, power adder?
Are you talking about the electrolysis of water into Hydrogen & Oxygen gas, or Brown Gas?
There is another topic somewhere else... Where people are discussing it...
But please... Go ahead...
Raf
Raf
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Car: GTA
Axle/Gears: Stock
Yes is another system like the ones found on the web. What we are doing is trying to imitate the Stan Meyers pulse generator method or better if we could. I am working on the fuel cell only, but my friends are working on the electrical part. Just yesterday I got my hands in one of those schematics supposedly the same as the ones Stan used and have a patent. I am going to give it to them so they can study it. Last day we talk on the phone and they already had something , but they wanted to make it all into a microprocessor. I dont like the microprocessor idea since the average joe can't replicate it easily, but they will provide with both methods; the microprocessor and the conventional using diodes and capacitors, etc...
If anyone have some good valuable idea, shoot them up.
From what I see, water can be broken up into HHO gas...
Now how valid the run your car on water sites are, they're supposedly adding some of that HHO gas to the regular intake (still using mostly gasoline)...
Anyway,
I saw through some other sites, that the rate of which the gas can be created is kinda slow (not enough to run a car)... I saw a guy that had a machine that produced about 10 times as much with less power...
Hmmm...
I was looking at chargers... a 12v charger and some others... There are companies that sell high frequency chargers... example.. think of a 60hz wave... well, a 120hz wav is like 2 60 hz wave's etc... they keep upping the frequency... understand? Here is the site that makes the high freq chargers, for some ideas...
http://soneil.com/features.html
Most people have it hooked up directly to 12v... if a microprocessor / converter were used, it could generate higher frequency waves, to maybe produce more gas... kinda like a woofer at 20 hz and a tweeter at 20,000 hz...
I know enough about electronics to be dangerous
Raf
Anyway,
Hmmm...
Raf
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Car: GTA
Axle/Gears: Stock
The schematics look the same as the ones I got my hands into, but the rest of the handbook (instructions), mine look much more proffesionally made.
I have friend who just told me that he has a friend that has a pickup truck running just with water only. He does have a bank of about three batteries on the rear just to convert the water to gas. He charges the batteries at home or something like that. Oh and another thing he also told me that he has some serious burns in his hands and chin due to not being carefull enough while working with the system. Hydrogen is much more powerfull than gasoline, is logical we just need to be much more cautious when working with it.
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
From what I've heard, it takes more energy to seperate the atoms than hydrogen produces....
Is this really possible? If it is, it can't be new technology, and what has stopped it from becoming a fuel for travel?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Engine: 383 Carb
Transmission: 4L60
Legitimate hydrogen powered cars don't really use hydrogen as a fuel, it's more of a convenient energy-storage and transportation mechanism. Electrical energy is used to separate hydrogen from water, distributed, and then allowed to recombine with oxygen to create water again in the engine, releasing the potential energy that was added during the decomposition of the water. It's still a net-loss system, it still takes more energy to decompose the hydrogen than you get out of it when you burn it. The advantage is that the electricity to produce hydrogen can be produced by "clean" and carbon-neutral sources of electricity, like solar, hydro, wind, nuclear, whatever.
Car: 91 rs
Axle/Gears: 3.50 9"
Here's my two cents, make lighter cars, drive smart=less need (requirement) for super safe heavy cars. Cars in europe are way lighter.
Also we should turn all stop signs into yeilds. Most of europe is this way, and it works well. How much fuel do you think we could save from not fully stopping? I bet it would be significant. Huge waste of energy.
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Car: 91 rs
Axle/Gears: 3.50 9"
Very interesting, here's a link from that site.
http://pesn.com/2006/04/16/9600261_J..._instructions/
I'm skeptical of just about everything until I see it in person, but there seems to be a lot of work going into this, and no one is pushing you to buy their product like scams often do. I've heard stories of "conspiracy theories" and people building "free energy" engines, only to have some guys (generally supposed big oil dogs) threaten them.
One guy, most of us should know, Smokey Yunik. I have heard he invented some engines that were very efficient, and the patents were "bought", and have been buried.
Ah, Smokey Yunik's Hot Vapor Engine...
Supposedly the gasoline in vapor form has more surface area (many tiny particles as opposed to one big one)...
I thought I heard the patents expired...
I remember companies saying / trying but couldn't control detonation (high temp's)...
There were 3 "secrets" to the engine, of which he told / showed 2 of them...
I wonder if he added water (as done with blown engines) to control detonation???
Just read recently that adding water, "the octane rating of water is virtually infinite... "how high would the compression need to be to get water to detonate?"... and water will cool the peak temps... Examples of a 17:1 compression tractor engine that ran on Kerosene (less than 50 octane) and water injection.... or 1100 hp 350 chevy running 35 psi boost on 87 octane... water injection works"
The Fiero he made with that engine was on Horsepower TV about a year ago... it ran, but it also had some technical difficulties
I read there is a working one at the University of Central Florida (where I graduated from) about an hour from Daytona... Would love to go see it
More info on that engine...
http://schou.dk/hvce/
Rafael
Rafael
Engine: 383 Carb
Transmission: 4L60
Car: 91 rs
Axle/Gears: 3.50 9"
My dutch isnt that good...
I've heard the octane rating of diesel is infinite, though its rated in septane.
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
here is where the real info is at...http://patft.uspto.gov/netacgi/nph-P...S=PN/4,503,833
i think what should be noted is the repeated mention of an electronic spark ignition... so most deisel principals go out the window... however the engines he picked 4cyl/2cyl... could turn around 5/6k rpms and still be effiecent however his peak numbers were down in the 4k range much like a deisel... also the repeated mention of 13deg of crankshaft rotation with the piston within .001 of TDC... tolerance like that should have extra attention payed to its importance.
what sorta makes me wonder is why this design would produce more POWER than a early compound deisel which was designed without a intercooler as i am sure they see some pretty healthy charge temps but the power output isnt anything out of the ordinairy for the given amount of fuel/air charge
Engine: 383 Carb
Transmission: 4L60
Octane rating and cetane ratings are different animals. Diesel doesn't have an infinite octane rating, but the octane rating is intended to measure the resistance to self-ignition. Diesel depends on self-ignition.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Apeiron, listen to this short synopsis about hydrogen being used as a fuel by Bob Lazar. Now, putting his "ufo" background to the side, he's still a credible scientist, and it's a very interesting interview nonetheless. There are more parts to the interview, but part 6 talks about the hydrogen, Click Here....
Engine: 383 Carb
Transmission: 4L60
I'd watch, but I'd rather get kill brain cells the old fashioned way: with beer.
Bob Lazar is not a credible scientist.
Originally Posted by Apeiron
I'd watch, but I'd rather get kill brain cells the old fashioned way: with beer. Bob Lazar is not a credible scientist.
Engine: 383 Carb
Transmission: 4L60
Hydrogen as a fuel is viable, especially when it's stored in a metal matrix, and run through a fuel cell to generate electricity... Systems which burn hydrogen in an internal combustion engine, or store gaseous hydrogen, or worse yet separate hydrogen from water on the car, will never, ever be viable. Anyone who claims they have made a viable system is either hopelessly mistaken, or a deliberate fraud.
Engine: 3xx ci tubo
Lots of Europe cars use small engines with turbos which gives better "normal driving" MPG. Kind of like why I put two T3 turbos of my 305ci TPI engine instead of going with a 454ci. I only need the extra power every once in a while and most of the time the engine is N/A small V8.
Legally blind guy building a Knight Rider replica chiming in again
Here is my 130 mile per gallon ride...
You can't buy this together, I bought an electric trike, it has about 10 mile range... I added a Honda Gas 4 stroke Generator and a Marine 24v Charger... I talked to all the engineers of the companies before buying / putting it all together... used all existing holes, only drilled 2 holes into Trike
Goes about 16 mph & still is considered an electric bike (no license) I just happen to be carrying a gas generator to charge it as I go
I wish a big company like Honda or someone would build something like this, unfortunately, the trike is made in Taiwan, we'll see how long it lasts... currently 500+ miles on it...
Raf
Raf
49cc moped
I use to ride them in FL but they changed the laws... From Tampa Bay to St. Augustine and everywhere in between... 5 hours from Tampa to Orlando back roads, 3 hours from Orlando to St. Augustine...
When I finish my Knight Rider car, if I can only convince the cop that "sir, the car was driving
Raf
I use to ride them in FL but they changed the laws... From Tampa Bay to St. Augustine and everywhere in between... 5 hours from Tampa to Orlando back roads, 3 hours from Orlando to St. Augustine...When I finish my Knight Rider car, if I can only convince the cop that "sir, the car was driving
" Raf
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Ya, those mopeds are a good time for just cruising around. MA laws are very lenient.... no insurance, 40 dollar registration for 2 years, just a drivers permit needed.
Now all you need to add is regenerative braking and a digital battery readout and you have a mini prius
Car: 91 RS
Engine: 350 vortec
really a mini prius... damnthings get any smaller and we will need to start breeding midgets to drive them...
Car: 91 rs
Axle/Gears: 3.50 9"
So is the general concensus for the "Joe Cell" calling B.S.? I am by no means a chemist, and this makes no sense to me, nor does it make sense why its not used for running generators or whatever, but....
What do these people have to gain by preaching this information? Just adding to the conspiracy theories?
Car: 91 RS
Engine: 350 vortec
from what i understand and what junkcltr and apeiron are saying is that you will always expend more energy seperating H and O than the resulting energy pruduced by the burning of H and O there for you will always need an external reneable power source...
could it be used to run a intermittent generator... probably with a solar panel to charge the batterys seems possible
Engine: 3xx ci tubo
It is all relative I guess. Most of the sport bike riders complain about the size of small bikes like the Ninja 250, GS250, etc. At the same time, the moped riders would like to be on something "that big".
If the water separation is powered by free energy (wind, sun, etc) then there is a gain. Price out some solar panels and a decent charger.....they aren't cheap. One can build a DIY windmill(s), but there isn't much wind in some areas. It is fun to play with though.
Don't forget nuclear, the only truly viable carbon free source we have left.
The rivers are all dammed, wind is too unreliable, solar is too expensive because it relies on rare elements...
Engine: 3xx ci tubo
Every time the topic comes up locally I always say nuclear is the way to go. Every one laughs at it. If you have a river/stream close by then that is a good option to change batteries with.
Yes, solar is expensive, but the parts last a long time. One other thing that many do not realize right now is electricity is relatively cheap. It hasn't increased at the rate it should have with the increasing fuel cost. The next rude awakening for consumers will be high electric bills.
Chuck84TA
Jul 15, 2016 09:05 PM
ambainb
Apr 25, 2016 09:21 PM
evilstuie
Apr 14, 2016 08:52 PM
sailtexas186548
Aug 24, 2015 10:11 PM
