What turbo are you guys using with your BBS headers?
Old Jun 26, 2008 | 03:01 PM
Jay87Z's Avatar
Car: 2000 Corvette FRC
Transmission: M6
Hey,
You guys running single turbo setups with the BBS Designs header... what turbo are you using?
I'm in the planning stages of a single turbo setup. It looks like the BBS header really limits the size of the turbo you can use (hood clearance). So I'm just curious what turbos you guys are using.
Old Jun 26, 2008 | 04:10 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: What turbo are you guys using with your BBS headers?
I believe the kits used to come with 60-1 or 62-1's IIRC Turbo TPI is in the 10's with one of those turbos
Old Jun 27, 2008 | 10:23 AM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
The header can handle a full T-76 with the hood closed.
Attached Thumbnails What turbo are you guys using with your BBS headers?-gta-t76-6.jpg
Old Jun 27, 2008 | 12:15 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
T72 here. only clearance issue was on the valve cover but easily "modified".
Old Jun 29, 2008 | 09:17 PM
Jay87Z's Avatar
Transmission: M6
Thanks for the info guys. I appreciate it.
What kind of modifying did you have to do? Do you think these "modified" valve covers would made the turbo fit without modifying anything?
http://www.hawksthirdgenparts.com/in...OD&ProdID=1044
Just trying to plan out my project I hate unexpected headaches, so I ask alot of questions
Old Jun 29, 2008 | 09:35 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
someone needs to make a 1 3/4 tube long single turbo hedder with crossover for a t6 turbo.
Old Jun 30, 2008 | 03:28 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
I just upgraded to a S400 BW turbo with a 4" DP. I had to trim a little of the under hood brace
Ray
Old Jun 30, 2008 | 04:28 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
is that s400 a t6 exh housing?
Old Jun 30, 2008 | 06:10 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
No T4 1.00a/r
Ray
Old Jun 30, 2008 | 08:34 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
they should make a kit with 1 3/4 1/2 flanges and a mount for a t6 exh housing. to fit the third gen . if they did i would proably buy it instead of welding my stailess steel set up right now.
Old Jul 1, 2008 | 08:47 AM
lock's Avatar
Car: 86 IROC-Z
Yeah I basically had to hammer the corner down on the valve cover... not much though. If seen other actually notch it sort of like your link.
Old Jul 1, 2008 | 05:01 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
I have a 62-1, but i think its at it max. So i am going to be upgrading to a turbonetics T-76. The one that is the same dimensions as the 62-1. So i know it will fit. Then we'll see if the ole L98 will hold together for some single digit passes.
Old Jul 1, 2008 | 05:26 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
^ Should hold as long as detonation is kept in check. My buddy Paul's Grand National is running with a race weight of 3475-lbs, stock ported iron heads, mild flat tappet cam, mease plenum w/70mm throttle body. Stock block, pistons, rods AND crank. 71-GTQ turbo, #75 delphi injectors, v2 FMIC, twin Walbro 340 fuel pumps, dual nozzle alkycontrol meth injection, stock headers, stock ECM w/Turbo Tweak chip, lc-1 WB w/directscan, innovative electric boost control w/HKS gate. Best run to date 10.41 @ 127, w/20+psi, Click Here....
Old Jul 1, 2008 | 06:21 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
the best part about that vid was the last race with the mustang on spray.
that dude was proably thinking i got this. lol
Old Jul 1, 2008 | 06:59 PM
^ That Mustang had a horrible reaction time, and an even worse sixty foot. Did you see the rubber he was running out back, it appeared he was running the stock rims w/tires for crying out loud. He should have been in the elevens, but either way though, he was still no match for the Grand National....
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
1984HO
Mar 19, 2021 11:59 AM
Zeek1041
Aug 21, 2015 08:45 PM
Street Lethal
Aug 14, 2015 08:25 PM
makaveli09
Aug 12, 2015 09:07 PM
