need to mount alternator on drivers side, low or mid mount... what bracket?
Old Sep 11, 2008 | 07:27 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
made my own single turbo setup,....
heres the problem: wastegate and down pipe run down the front passenger side of the motor, and also am using an electric water pump, so i need to mount my alternator low or mid on the drivers side,... i am using an S10 manual steering box so no powersteering to worry about.
is there something out there that will mount it there and clear steering stuff..
i tried the jegs low mount driver side bracket and it doesnt clear the pitman arm.
im trying desperately to get this car running in the next two weeks.
i'll be posting pics when i get the new turbo in the mail.... Turbonetics T76....
any advice would be great, thanks in advance, Keith
Old Sep 13, 2008 | 12:45 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Re: need to mount alternator on drivers side, low or mid mount... what bracket?
Have you tried looking at Alan Grove's brackets? Might be somethere in there you could try.
http://alangrovecomponents.com/short_pump.htm
Old Sep 14, 2008 | 06:51 PM
Car: 91 camaro rs
I actually was able to make a low-mid mounted bracketout of some metal i had laying around, and was able to retain my intercooler pipes the way i had originally intended.
thank you very much tho, those look like some nice brackets, next year i will probably look into that EVAC bracket.
thanks
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
Elliswon
Aug 10, 2015 12:33 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
