turbo with maf
Old Oct 1, 2008 | 06:35 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
turbo with maf
Hi all,
i have seen conflicting answers, so i was wondering if someone could tell me if the maf goes before or after the turbo? I saw a youtube video of it being installed and run in its normal spot (just before intake) with good results, and i saw a big turbo install writeup on here that says put the maf on the turbo inlet. any ideas?
Old Oct 2, 2008 | 10:16 AM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Re: turbo with maf
On our cars, install it between the turbo and throttle body.
Old Oct 2, 2008 | 10:44 AM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Re: turbo with maf
FWIW, Grand nationals have the MAF before the inlet of the turbo, after the filter of coarse. They run fast so it must be ok.
Old Oct 2, 2008 | 04:50 PM
project89's Avatar
Re: turbo with maf
it depends on the maf sensor, a plastic stock thirdgen maf should not be used on the presure side of the turbo system (i.e blow threw)
they should be used on the suction side i.e turbo inlet
now if u run an ls1 or lt1 maf with a translator u can run it in either location
Old Oct 3, 2008 | 06:16 AM
thunder85's Avatar
Engine: 5.7L w/hsr
Re: turbo with maf
where would i snag a translator? or are there schematics available somewhere?
Old Oct 3, 2008 | 11:42 AM
project89's Avatar
Re: turbo with maf
http://www.maftpro.com/
Old Oct 3, 2008 | 01:39 PM
thunder85's Avatar
Engine: 5.7L w/hsr
Re: turbo with maf
as i have a l98 tpi, would i use the lt1 model or get the genII or pro unit? do you have one?
Old Oct 3, 2008 | 01:41 PM
project89's Avatar
Re: turbo with maf
i dont run one, i ran my stock maf on the inlet side of the turbo then i went with a standalone system that runs speed density not maf.
im sur eone of the v8 turbo guys here can shime in and tell u which on u need to get
Old Oct 3, 2008 | 11:24 PM
thunder85's Avatar
Engine: 5.7L w/hsr
Re: turbo with maf
anyone? is there a plug n play translator for a new maf onto an L98 tpi setup?
Mark_ZZ3
May 24, 2018 01:02 PM
cheesehomer
Dec 31, 2015 08:48 AM
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
