Single turbo project
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Axle/Gears: 9inch 3.50 gear
Building my first turbo/blowthrough. 89 firebird, 383,e-85, csu carb and s475 with 1.10 a/r turbo. here are some pics of the progress.
http://i180.photobucket.com/albums/x...Picture001.jpg
http://i180.photobucket.com/albums/x...Picture002.jpg
http://i180.photobucket.com/albums/x...Picture003.jpg
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Single turbo project
That turbo is a friggin MONSTER! my buddy has the same turbo getting ready to instal on an Ls1......you should definately fly,if you can get it to boost early.
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Wow awesome looking setup and car...I guess there is another alternative for me move the rad WAY forward lol. IM also doing a T6 turbo in my Iroc.
You should post your build on theturboforums.com!
Here is my progress on CamaroZ28.com since its picture friendly if ur not registerd
http://www.camaroz28.com/forums/showthread.php?t=646416
Jay
Jay
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Are those the ebay headers?
No meth injection? Figuring the E85 will cool the air well enough? Are you going to monitor IAT's?
Very nice, this is a setup I have been wondering about.
Car: 83Z28 HO
Transmission: G Force 5 speed
For safety's sake, keep your head away from that turbo inlet!! lol
That thing's HUGE! Should outright fly if you can keep it on the road. Nice!
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
I will not be using meth injection, the E-85 should have a good cool charge, i will be watching IAT,EGT, will be using a data logger also. yes thay are the e-bay headers modified.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I'm planning a similar build! i'm using your old shorties *well one of them* to do mine. I was planning on that turbo too but on a T4 flange. Not sure if its gonna fit under the hood with the BBS manifold, that thing looks much bigger than i thought it would be
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
yeah soon as the spring hits....my camaro is gettin hit with a s475 1.32ar along with jgs bov and wgate....im gonna try not to move my rad, and i see your not runnin a intercooler....even with the cooler injection....i still would if i was you....just a though....nice welds tho....who did those you...
another set of ebay headers with the flanges cut/swapped for v-bands.
- Looking good man. A bit suprised you fit that down under that hood.
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
The driver header did not clear steering shaft had to cut rear header tube #7 cyl. and turn tube 180 and re tig fits very nice now.
Car: 92 Camaro Z28
I have a S400 T4 on the BBS manifold. I'm running a 3" charge pipe and a 4" Downpipe. I did have to cut a small section of the under hood brace.
4" Downpipe
Ray
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Looks good
Can you get that pass. valve cover off with the turbo their?
Can you get that pass. valve cover off with the turbo their? Joined: Sep 2003
Car: 89 Iroc-z
Transmission: TH400
good deal, that looks fantastic! what do you guys do about a rad overfill bottle?
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
just get aftermarket overfill bottle you can mount it anywhere youl like.
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
you might want to move the msd box inside the car...............supposed to keep them away from extreme heat.looks good tho
Car: 92 Camaro Z28
I'm running a overflow btl from a older supra. If you look just right of the hood latch you can see the top of the btl. No way to get valve cover off with turbo on. But to get the valve cover off really isn't very hard at all since everything is V-band clamps, and 4 bolts. I'm in the process of installing a JGS 50R WG.
Ray
Ray
Engine: 355 carbed
Transmission: 4 speed!
Axle/Gears: 3:23 Welded!
Hey. that looks AWSOME! let me know how the tuning goes with that. as im also going to try and do a turbo/blow through carb setup and am curious as to how hard they are to tune and what i should do about the distributor weights and such. except im going to do a rear mount turbo because i dont need the extra power right away, just from 4000-6500.
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
STOP IT!
THese are awsome setups. I keep telling myself that I am not going to modify my car anymore, and you guys keep showing me these awsome trubo projects.
If you do not mind me asking. How does that S400 setup run and what are the specs on that S400.
THese are awsome setups. I keep telling myself that I am not going to modify my car anymore, and you guys keep showing me these awsome trubo projects. If you do not mind me asking. How does that S400 setup run and what are the specs on that S400.
Hotrodboba400
Dec 10, 2019 07:07 PM
