Who Makes the quietest Centrif Supercharger
Old Dec 9, 2008 | 10:52 AM
Slowridr's Avatar
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Wondering who produces the quietest centrifigal supercharger. More or less concerned about the whine they make. Are some quiet at idle but whine loud under WOT or vice versa?
Old Dec 9, 2008 | 12:30 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Who Makes the quietest Centrif Supercharger
Powerdyne BD series, like the BD11A.. Very quiet. Doesn't make a lot of boost though. around 5-6psi tops on my motor. Impeller upgrades put it in the same territory as an S-trim. figure about 800cfm as is, 1,000cfm with the impeller upgrade.
-- Joe
Old Dec 9, 2008 | 06:46 PM
Slowridr's Avatar
I assume your vette has an L98 in it? What kinda pwr does it make? If you dont mind me asking how much $$$$ for turnkey install? How dependable is this SC?
Old Dec 9, 2008 | 08:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
my buddy has a procharger p1sc on his L98 formy and i seen a guy with a procharger something on his 99-04 GT stang. Both are pretty noticeable at idle and really loud with some rpm. The formy's is a touch quieter tho than the stangs so i'm not sure what that guy may have. Maybe the D1?
My buddy's local shop has the F1R procharger on their LT1 powered blazer and its whiney. Very noticeable
My other buddy i work with and went to school with picked up a vortech blown LS1 TA 2-3 years ago i guess. Its been awhile since i heard it but its noticeable on revs but at idle its pretty tame. His exhaust is pretty loud at WOT and i didnt hear much blower whine. I'd say the vortech is abit quieter than the procharger
But its been alittle while since i've heard them last. Boost level probly makes the difference but then again, the L98 was running close to 12 lbs and that GT i bet wasnt running anymore than 9 as most GT's wont hold much more than 9psi. GT was louder. Who knows
Old Dec 9, 2008 | 09:08 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
my P1SC is very noticeable at idle but once you start revving you dont notice it as much.
Old Dec 9, 2008 | 10:39 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Powerdyne is the quietest because it is belt driven internally.
Old Dec 10, 2008 | 05:43 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
My vette had an L98 in it. It's a 4 bolt main block, bored .040 over, trickflow heads, 10:1 compression, angle milling (valve roll), singleplane intake, LSx throttle body, and some other custom parts. Around 500 crank horsepower through headers and a stock LTx dual exhaust (dual 2.5" w/ resonator)
My blower setup cost me around $1800 for everything, but I need to replace the fuel pump with a larger unit. If the AC was deleted from the car, making a bracket for a BD11A straight discharge on the passenger side would be easy for machine shop. Mock one up with some 3/4" plywood then send the template to a machine shop. The discharge when straight would aim at the driver side, so basically all you need is two flex couplings and a straight.
An Fbody has tons of under hood room for goodies. Vette not so much. GM almost intended the Fbody to be tinkered with by gearheads, where the vette was marketed towards fat rich white guys and their coke snorting wives.
-- Joe
Old Dec 10, 2008 | 05:08 PM
Slowridr's Avatar
Old Dec 10, 2008 | 05:14 PM
Slowridr's Avatar
What type of durability does the Powerdyne have. I like the idea of getting more power while not being noisey.
Old Dec 10, 2008 | 05:25 PM
Slowridr's Avatar
Went to Powerdynes website. Like what Ive read there. I dont see listings for L98s. Can this be made to work on an L98?
I guess I should ask them too.
Old Dec 10, 2008 | 08:39 PM
Engine: LO3
Dont know how true this is but i heard that the internal belts on those things go pretty often especially more so with more boost.
Old Dec 10, 2008 | 09:33 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Powerdyne went bankrupt, so ignore their website. 02force owns and produces powerdyne superchargers under the "scorpion" line. The model numbers are the same. (BD11A, XD).
The belts do break. I think if your BOV is properly functioning it should be fine.
They don't make a "KIT" for L98s. You can make a bracket like I suggested, or contact Greg Carrol from blowerworks and see if he will sell a 'kit' for an l98 fbody.
If I had a fbody, I'd delete the AC and mount the head unit where the AC was.
-- Joe
Old Dec 10, 2008 | 11:45 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I have been running a Powerdyne on my Yukon for about 5-6 years now, very reliable and very quiet ! I am getting 11 lbs of boost out of it and no problems thus far !
Jason
Old Dec 11, 2008 | 10:27 AM
tequilaboy's Avatar
I recently heard a Vortech V2 SQ Si-trim with a 3.5" pulley IIRC which was installed in an L98 vette. It was also very quiet. It sounded very similar to my Powerdyne. Just a little whistling could be heard.
deracer
Apr 11, 2016 12:04 AM
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
