vacuum problem...
Old Jan 9, 2009 | 10:20 PM
areonic1's Avatar
vacuum problem...
Alright, so I got my boost gauge hooked up, at idle it reads I guess -20...I have boost set to run 8psi, but when I get on it, it never goes that high. Is it normal to read -20?
Also, where do yall tap in, to get boost gauge readings, map readings, and for BOV's?
Any help would be awsome, THanks
Old Jan 9, 2009 | 10:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: vacuum problem...
20 inHg isn't unusual
Old Jan 9, 2009 | 10:39 PM
areonic1's Avatar
What do you mean?
Like, take a normal boost gauge, goes from 40 to 0, then 0 to 40 clockwise around the gauge. Its reading the bottom 20 at idle, slowly goes up when hitting throttle, but it doesnt go over the 0, is that normal? do i have a vac leak? and does my altitude matter where I live?
Also, im still trying to find a good vacuum source for it..there is a hose coming out of the top part of the motor, on the passenger side, its a short5inch hose, goes into this short round, plastic thing, then back into a vac hose, and carries on....
Old Jan 9, 2009 | 10:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's normal on a naturally aspirated car.
Old Jan 9, 2009 | 11:14 PM
areonic1's Avatar
Well its turbo now, if that matters
Old Jan 9, 2009 | 11:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If it is, you haven't got any boost.
Old Jan 9, 2009 | 11:24 PM
areonic1's Avatar
What should it be at, at just idle with a turbo?
Old Jan 9, 2009 | 11:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The same as it would be at idle without a turbo.
Old Jan 10, 2009 | 03:11 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
It should go to zero at WOT, and then up with boost. And make sure you are connected to a manifold vacuum source, as in from the intake plenum. Such as the one that goes to the brake booster, etc.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
