Turbo and Size
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
Turbo and Size
i have a 350 motor will 11k miles on it im putting in a double roller timing chain comp cam 256xe .447 .454 weiand intake holley 4 barrel carb ud pulley set i was just wondering what kind of turbo i should get and the size that will work on this motor with out blowing it i want to run around 6lbs of boost thanks
Transmission: 4L80E/4L80E
Well, this is a better fit for the Power Adder forum than the Carburetor forum.
Linson
Sep 21, 2015 01:08 PM
