turbo carb???
Old Mar 11, 2009 | 12:38 PM
wes2008's Avatar
Car: 1992 Rs camaro
Engine: 3.1l
Transmission: 700-4
turbo carb???
i have a 302ci engine with aftermarket cam a 600cfm carb single feed. i wanted to know if a speed shop could covert it to a blow through? and do you'll think it will be big enough for about 8-10psi?
Old Mar 11, 2009 | 01:46 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: turbo carb???
visit turbomustangs.com thay have a basic thread about converting your holley double pumper to basic entry level blow thru. not hard at all, and works well. ive done the conversion before. detailed with pics. also all kind of info and tech related to blow thru, found there.
Old Mar 11, 2009 | 01:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: turbo carb???
Are you not quite catching the hint here guy? I told you yesterday to go to turbomustangs, and your thread was locked. Now you start two new threads on the same subject, only to get the same response.
Catch the hint - turbocharging an old ford mustang is not the topic here. Go to turbomustangs.com. They have more information, more experts, and it's a forum meant for that! Don't clutter up the camaro forum with information that may or may not be useful to us.
Old Mar 12, 2009 | 11:50 PM
5.0slayer's Avatar
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
Re: turbo carb???
idk if its a guy being a D bag or not but they did make a 302 chevy v8, but thats just my 2 cents
Old Mar 13, 2009 | 09:21 AM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Re: turbo carb???
while that happens to be true, I doubt someone with an engine of that type would be on this board. an actual chevrolet 302 was only produced for 3 years (67-69) for the trans-am racing series which had a 305 limit on displacement.
and on a side note, turbomustangs.com is an awesome turbo forum for any vehicle lookin to add some boost.
Old Mar 13, 2009 | 12:29 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: turbo carb???
I want a old chevy 302 they are awesome engines
Old Mar 13, 2009 | 12:34 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: turbo carb???
Sounds sweet. Good luck!
Old Mar 13, 2009 | 12:45 PM
Re: turbo carb???
Just checkin to see if avitar is up......
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
makaveli09
Sep 15, 2015 10:43 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
