Modified BBS turbo manifold for S475
Old Mar 19, 2009 | 09:24 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
I'm running a BW S475 Turbo on a BBS manifold. As most of you know the BBS manifold uses a 38mm WG. Well that WG is WAY to small the S475. So I got a JGS 50R WG with uses a 2" tube. So I had to modify my manifold. Here is a picture before getting it ceramic coated.
Ray
Old Mar 19, 2009 | 09:50 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Modified BBS turbo manifold for S475
Good deal, i was gonna do that to my BBS manifold before i went with a twin setup. Looks good.
Old Mar 22, 2009 | 11:24 AM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
Looks great. Are you going to add some sort of support bracket? S400's are HEAVY!
Old Mar 22, 2009 | 05:57 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
I've been tring to come up with somthing, but not much luck yet....
Ray
Old Mar 23, 2009 | 05:20 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
what you do, weld a t6 flange on the bbs
Old Mar 23, 2009 | 05:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
He modified the wastegate tube for a larger wastegate to control boost on a single turbo application, its in his first post
But you bring up a good point. Looks like a T4 flange as you can get the S400 on a T4 flange. A t6 is massive and that single tube that the BBS is design around is not big enough to fill the T6 opening
Old Mar 24, 2009 | 12:11 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
Its a T4 S400....
Ray
Old Mar 24, 2009 | 11:32 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Vary nice. Please post dyno numbers. I have a bbs header with a T76 turbonetics turbo that will be going on next winter and would like to know the limits of this header.
Old Mar 30, 2009 | 12:22 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
can't see the pics? link still work?
Old Mar 30, 2009 | 06:37 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
I'm curious what kind of pulley system you are running for the belt-driven accessories?
Old Mar 30, 2009 | 11:52 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I believe he is running manual steering and a driver side low mount alternator bracket that could be had from Jegs or summit.
Old Mar 31, 2009 | 07:56 AM
rtkjadams's Avatar
Car: 92 Camaro Z28
That is correct ... The alternator and bracket are a Powermaster, which I got from summit. S10 manual steering box.
Ray
Old Mar 31, 2009 | 08:42 AM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Looks good. I blocked the stock wastegate tube like you did and put the wastegate under the car on the cross over pipe on my setup. I might end up moving it back up on the turbo header tho. So i can route it right back into the downpipe.
Old Mar 31, 2009 | 05:12 PM
Charged350's Avatar
Car: 87 IROC Z28
is the WG vented into the DP or jus open ...
Old Apr 2, 2009 | 05:22 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
Currently it is open, but I want to run it to the DP...... My wife keeps asking me If I'm done with the car..... I told her it will never be done!
Ray
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Rally Smith
Sep 14, 2015 06:59 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
