the trans am's gettin a turbo please help
i got a 1986 trans am 305 tpi with 102k miles it runs pritty good but weak so turbo time.
im tryin to run like 7lbs of boost(will it hold or blow up)?
whats a good turbo that will put out 7lbs?
what manifold do i get?
what are other mods i will have to do to make it work like injectors chip or w/e
please help me out im a turbo noob
thanks!
thanks!
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: the trans am's gettin a turbo please help
okay for a 305 run like a T67 or a T70. Masterpower makes a cheap affordable good turbo.
For manifolds you could try to find a BBS designs kit used OR buy the ebay headers (point forward ones) You may need to modify the back tube on the drivers side to go around the steering shaft.
The just build a merge off the headers to the turbo. If you have some welding skills its not all that bad to do.
Injectors if your staying around like a 400hp build some 42#s should do the work.
Wastegate, you will prob need a 50MM wastegate to hold 7psi. I bought the X02 racing 50mm as alot of people on the theturboforums.com have had luck with them and there about 150us.
If it is a stock motor I would say run an intercooler and possible meth kit if you can afford it.
ECM i have no idea as I have an LT1 swap in mine.
Jay
Jay
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
A single on the passenger side using something like this:
http://xs-power.com/gm-turbo-manifolds-3.htm
or something from BBS Designs would work.
Throw a T4 turbine with a 60 - 70mm compressor inducer on top of the manifold.
Get a 50mm or 38mm wastegate off Ebay or SSAC
Some Ford (cheap) 42 #/hr injectors
Walbro 255lph pump
GM 730ecm with $59 code
2-bar map sensor
Ebay 12x24x4 intercooler
some couplings and clamps from www.siliconestop.com (cheapest around)
some down pipe pieces and clamps.
Some oil lines (in & out)
Pump, check valve, fittings from www.coolingmist.com
For under $1500 you could have all the above including IC and alky/water injection and have a turbo good for up to 600-700HP. A stock 305ci TPI high compression (9.5:1) engine could easily make over 400 BHP using that setup with 91-93 octane pump gas.
You can always up the boost and make more HP later on when you run better gas or lower the compression.
Walbro 255lph pump
2-bar map sensor
do you guys think its gonna blow up. it smokes because it needs gaskets some oil leaking into the cylinders. or will this not effect anything. has an ocassional misfire. wondering what max boost on a 305 tpi would be also.
Engine: 3xx ci tubo
No one can answer if it will blow. If it helps, I have a 1986 305ci TPI with 130K+ miles on it. All bone stock with a DIY turbo kit. I run around 11-12PSI right now.
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Dude...you want to put a turbo (even a DIY setup) on a motor that needs gaskets, is leaking oil into the cylinders and misfiring???!!!
Not telling you what to do, but you need to atleast make sure your motor is in decent running condition. If the idea that it will blow up is even remotely in your mind, you have some work to do before you start adding boost.
There are quite a few threads around here with junkyard and DIY turbo builds. I would spend a few hours searching around. Find the guys that are running them now, and ask lots of questions.
Ive seen guys get fairly decent results for pretty cheap on a stock motor. Just gotta do your homework and build away.
J.
J.
it runs good but it just smokes blue like they all do. is 7 pounds that much to worry about. i mean the car runs good enough to spin 1st gear forever and then spin second. it still has power. idk what to do yet thats why im tryin to find info but i couldnt find anything on a boosted stock 305tpi.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by louflemm
it runs good but it just smokes blue like they all do....
Engine: 3xx ci tubo
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
how does one replace the valve seals?
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
man I feel like everyone is saying 42 lbs injectors is a small injector and cant support much power. I guess that not many people can tune that well or I am awful lucky. I have yet to dyno it but for the mph it is making we are guessing 550 to 600 rwhp. any way the reason I decided to chime on in is your engine management. You need to swap over to a 730 or 749 ecm and run code $59. That will allow you to tune up to 30lbs of boost with a 3 bar map. I run it on mine with a 730 ecm. see sig for combo but I will say it runs pretty good for a home built setup. I have pictures all over power adder forum just search under my name. Pics of it from start to finish. I will say I am out of injector at 7 lbs of boost and 50 lbs of fuel pressure and should go to a 60 lbs injector so I can run the 12 lbs I want to run.
Engine: 3xx ci tubo
42 lb injectors at that fuel pressure will do the HP you mentioned just fine.
bjpotter
Jan 22, 2019 12:27 PM
lt1z350
Sep 29, 2015 01:50 PM
