whats missing
Old Apr 18, 2009 | 01:19 PM
gibsongod716's Avatar
Car: 85 Trans Am / 64 Chevy Nova
Engine: Turbocharged 355ci / 383ci
Transmission: WC T-5 / T10
Axle/Gears: 3.45 / 4.11
whats missing
See pictures
Attached Thumbnails whats missing-0414092056.jpg   whats missing-0416091831.jpg   whats missing-0417091816.jpg
Re: whats missing
extra
Old Apr 18, 2009 | 09:25 PM
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
Re: whats missing
an f-body with a motor/trans/ect ect to support forced induction?
Old Apr 18, 2009 | 10:13 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
Re: whats missing
whats the stick welder for, you fixin a fence?
think you should invest in a mig!
Old Apr 19, 2009 | 09:14 AM
Re: whats missing
no thats just for running the downpipe and such along with the buttjoint clamps lol
i was hinting at the fact there is no manifolds so i came up with a sketch of how Im going to run it, tell me if you think its good
Old Apr 19, 2009 | 04:28 PM
50bmgshooter's Avatar
Re: whats missing
yea take that arc and toss it please
get a mig or better yet a tig
sorry but i have to agree with iroc.86
Old Apr 19, 2009 | 04:36 PM
Re: whats missing
the stick welder although its a pita to use actually welded pretty good, i had a test run overnight i attached a twenty five pound weight to the end of test pipe and the weld didnt break nor rupture, so far so good, just hope it can hold boost
Old Apr 19, 2009 | 10:07 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: whats missing
Is that a Chicago Electric 80Amp DC stick 115v input? It will weld pipes together, but will never weld pipe to a header flange without pre-heat or multiple passes.
You can turn that into a TIG welder and do the pipes if it is DC output. All you need is a torch with a gas valve, a regulator, and a bottle of argon. A MIG would have been easier in the long run, but that ARC will work for most of the stuff if it is steel or stainless steel.
Old Apr 20, 2009 | 07:37 AM
Re: whats missing
arc will definatly work just mig and or tig is much neater
Old Apr 20, 2009 | 09:25 AM
Re: whats missing
yeah everything is plain old steel, gonna get painted with high heat paint when its done and wrapped with some exhaust wrap. I plan on making a decent weld from the header flange/cast iron(cutting off the bell part of the flange) to the exhaust pipe/steel and than clamp it with a walker clamp for added control
Fireslash
Apr 11, 2016 06:43 PM
sammy52401
Nov 11, 2015 07:20 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
lewandom
Oct 1, 2015 08:15 AM
