Boost, How Much ?
Boost, How Much ?
Hi,
I have a 383 stroker with forged internals, aluminum heads, holley SR & 950pro ECU the engine is just a hair under 10.1 compression I'm going to be installing a procharger with intercooler and wanted to know with the compression I have how much boost can I run and still be on the safe side? I was told 9lb would be "ok" would like some advice
thanks
thanks
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: Boost, How Much ?
Procharger says 15#'s with 9.5:1 compression, you have forged internals which is a plus
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
altitude?
camshaft?
head style?
I would like 6-9psi is "safe". I think even intercooled, 15psi on 10:1 CR is wayyy too much, even with 91 octane.
But that's why new driven sprokets are so cheap, you just swap to get the right boost level.
camshaft?
head style?
Heres the fully details on the engine, altitude not sure? Illinois is that gives you any thing?
Full MSD Ignition AL6, Pro Billet 8366 dizzy, coil & wires
Block: 350 bored over .030, eagle forged stroker crank, H beam 5.7 rods, SRP -16cc dish pistons 9.8:1 Compression
Heads: Dart pro 1 aluminum heads, 200cc, 64cc chamber, 2.02/1.60 3 angle valves, gasket matched to flet-pro 1405 and to the Steath Ram Heartland sharp 1.5 roller rockers
Cam: Comp Cam XR269HR-12
Advertised Duration
269 int./276 exh.
Advertised Exhaust Duration
276
Advertised Intake Duration
269
Basic Operating RPM Range
1,500-5,500
Cam Style
Hydraulic roller tappet
Computer Controlled Compatible
No
Duration at 050 inch Lift
218 int./224 exh.
Exhaust Duration at 050 inch Lift
224
Exhaust Valve Lash
0.000 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio
0.503 in.
Grind Number
CS XR269HR-12
Intake Duration at 050 inch Lift
218
Intake Valve Lash
0.000 in.
Intake Valve Lift with Factory Rocker Arm Ratio
0.495 in.
Lobe Separation (degrees)
112
.0.495 int./0.503 exh
269 int./276 exh.
276
269
1,500-5,500
Cam Style
No
218 int./224 exh.
224
Exhaust Valve Lash
0.000 in.
0.503 in.
Grind Number
CS XR269HR-12
218
Intake Valve Lash
0.000 in.
0.495 in.
112
Car: 1982 Trans-Am
I think 6-9psi is pushing it.
That's 10:1 with a very tame cam. Even intercooled, you won't get much boost.
Car: 1986 Camaro SC
dude 10#'s should be safe, i'm pushing 14# on a stock bottom end 9.5:1 305 short block, as long as your tune is good you should be fine.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
8-10psi if you change the cam, and have proper quench.
That cam is going to put the DCR too high. You'll end up having to lock your advance in around 22 degrees.
-- Joe
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I would think it would be fine. LT1 kits make around 6-8 psi and they're 10:1. Run a bad tune and too much timing and it'll surely detonate though.
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
