compressor reference port?
Old Apr 19, 2009 | 03:48 PM
gibsongod716's Avatar
Car: 85 Trans Am / 64 Chevy Nova
Engine: Turbocharged 355ci / 383ci
Transmission: WC T-5 / T10
Axle/Gears: 3.45 / 4.11
Ok I'm going to install a manual boost controller and it says locate the compressor reference port. I'm 100% positive my turbo doesnt have any port besides for a little square which appears to be factory welded shut. Please help! Can I run it to a carburetor vacuum source or intake manifold source or even the blow off valve vacuum port instead?
Attached Thumbnails compressor reference port?-0419091655a.jpg   compressor reference port?-0419091655.jpg
Old Apr 20, 2009 | 12:26 PM
Re: compressor reference port?
anyone?
Old Apr 21, 2009 | 08:42 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
You can reference the boost controller anywhere between the compressor and throttle blades. It just needs to see positive pressure (boost). I would not recommend using a vacuum source.
Old Apr 21, 2009 | 05:42 PM
there is no port or anything between the compressor and turbine blades... Would it be possible to use an intake manifold or vacuum port? Or could I weld a bung on my intake pipe and run a vacuum line to that?
Old Apr 21, 2009 | 06:02 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Yes, you'll have to create your own reference point by either welding or tapping a fitting in your compressor, intake tubing, or elbow.
Old Apr 21, 2009 | 06:12 PM
so just to clarify because I dont really feel comfortable drilling into my compressor lol, I can attach a hose to the pipe containing the blow off valve if I wanted?
Old Apr 21, 2009 | 06:52 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
The red arrow points to where I tapped my TB hat for the boost controller/wastegate reference point. The blue arrows are other places along the intake tubing that would've also worked.
Old Apr 21, 2009 | 06:55 PM
oh cool thanks alot for the picture, i appreciate it, ill probably weld it right after the compressor than just so i dont have to run like 5 feet of line. thanks again
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
