Fuel pressure regulator, a neccessity?
Car: 85 Trans Am / 64 Chevy Nova
Engine: Turbocharged 355ci / 383ci
Transmission: WC T-5 / T10
Axle/Gears: 3.45 / 4.11
Ok heres my setup
Engine: 355 w/ forged crank
Carb: Mighty Demon 750cfm annular
Turbo: T70 with a .70 cold and .84 hot
Fuel Pump: GM PP 110gph
I figure I'm gonna be running between 5 and 13 pounds based upon racing locations, so can I get away with tuning the carb without one, or should I pick one up, if so which do you guys recommend?
Car: 1987 IROC
Axle/Gears: 10-Bolt 3.73
Re: Fuel pressure regulator, a neccessity?
Ok heres my setup
Yes, you need a boost referenced fuel reg before that engine see's any boost or.........boom
Also, I hope that's a blow-thru carb?
The fuel pump is at 8psi I forgot to mention
Yes its a Mighty Demon Blow Thru 750 cfm carburetor
And do the ebay fuel pressure regulators work, I'm already in debt cause of this project and cant afford a racing regulator
Car: 1987 IROC
I've never ran a mech pump on a blow-thru app so hopefully someone else can point you in the right direction. Too me, that pump seems alittle small unless your keeping boost very low. How much HP are you planning to make?
How would I run a line to the fuel pump?? Would it require me drilling into it? I also plan on around 500 to 600 hp and it says that the 130 is good for up to 800 hp so i figured 110 should be good enuff
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Back when I had a blowthru carb, I modified a Carter mech fuel pump for the turbo. Just attach a rubber line from the carb hat to the fitting on the pump and the fuel pressure will increase 1:1 with boost. I still have it if you want it.
How'd you get it into the fuel pump like that, I dont think my pump has them ports...
Also my fuel pump has 3 ports, an inlet, an outlet, and a return
Car: '85 TA
Engine: 350 turbo
The stock pump also had a return line from the mech. pump, but I didn't use it when I replaced it with the Carter.
On the Carter pump, there was already a hole on one side that referenced atmosphere, so I just drilled the other side and installed two fittings.
Is this guy any good, it looks like it has a ref. port on it plus its 110gph and it has 3/8" fitting, which is what I have now
http://www.summitracing.com/parts/SUM-250020-1/
9192camaro
16
Feb 3, 2019 12:21 AM
