89 TT T/A Finally Running!
Old Aug 19, 2009 | 02:28 PM
Car_2's Avatar
Car: 89 Trans AM & 69 RS/SS Camaro
Engine: 400 "little M"
Transmission: Tremec TKO II
Axle/Gears: Moser 9" with 3.50's
After a long build, i finally started it up last night. If i can get the charging system working, i may be able to take it for a ride in a couple days!
Here are some picks of my work!!!
Attached Thumbnails 89 TT T/A Finally Running!-p1010020.jpg   89 TT T/A Finally Running!-p1010023.jpg   89 TT T/A Finally Running!-p1010022.jpg
Old Aug 20, 2009 | 07:43 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: 89 TT T/A Finally Running!
Everything looks nice and shiny .. except those valve covers. Do you have any better pics in front of the engine so I can see the turbos and the rest of the compressor outlet tubing? Can you post the specs of the engine & turbo components?
Old Aug 20, 2009 | 11:14 AM
Car_2's Avatar
lol! i did buy some fabricated aluminum valve covers, i need to weld some -10 bungs on them so i havnt put them on yet... i can get some picks of the front of the engine. although when its all put together, its hard to see everthing in pictures.
this thing has been in the works for 3 1/2 years, since i dont have a unlimited budget and i like the nice stuff, i just had to do all the work myself and do this over a long period of time.
here are some of my specs, i will list the high points
400ci small block,
dart little m
afr 190's
je pistons 7.5ish cr with my 74cc heads
scat 4340 crank
scat h beam rods
cam motion turbo cam
fast xfi
precision sc60r turbos, .84ar ?? on the turbine.
precision 750hp intercooler
tial 38mm wastegates, and 50mm?? bov.
tpis intake
Old Aug 23, 2009 | 10:37 PM
Car_2's Avatar
Been driving the car. put on 110 miles today. only running on the wastegate spring. boost guage only shows 5 psi .. its faster than when i had a n/a 383 that was 350hp to the tires.
I have to fix the brakes before i crank up the boost. I went with a ed quay manual brake conversion. strange 1-1/8 master cylinder, pedal modification, 1le front and rear brakes, dont like the brakes at all. I have to push real hard, and it still dosnt stop as fast as power brakes. Not sure what to do. Suggestions?
here are some more pics of the car. I try to keep the car looking stock.
Attached Thumbnails 89 TT T/A Finally Running!-p1010025.jpg   89 TT T/A Finally Running!-p1010027.jpg   89 TT T/A Finally Running!-p1010029.jpg
Old Aug 24, 2009 | 10:44 AM
superirocz's Avatar
How about a hydraboost?
I put one on my car its very easy and gives you allot of room. I didn't buy one of those expensive kits I used a 94 astro van HB the same thing the expensive kits use.
Picture is kinda crappy but you can see how my headers run tight on that side. Now with my HB I have plenty of room, no more huge booster in the way.
Attached Thumbnails 89 TT T/A Finally Running!-turbo-iroc-001.jpg
Old Aug 25, 2009 | 05:06 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Very nice car. I like the sleeper look. Very similar to mine.
Old Sep 3, 2009 | 10:26 AM
raceman094's Avatar
nice setup. was wondering what you did for tuning.i noticed the msd box, didnt know if it was the boost retard or what. i hve all the stuff to do a tt setup on an lt1 and havent seen any good info on the computer aspect.
Old Sep 4, 2009 | 07:57 AM
Car_2's Avatar
I use a FAST XFI. i have used the factory ecu's 165's, 7730's, i even have a few 749's that i never used... i could just never get the hang of the factory tuning, so i spent the money on the xfi. Which for me, was money well spent. no more tuning headaches.. well maybe a couple... but that has to do with idle and 95lb injectors..
Frozer!!!
Jan 19, 2024 04:55 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
Polo Z03
Sep 10, 2015 06:43 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
kyleb24
Aug 15, 2015 08:24 AM
