super charge with nitrous
Old Nov 5, 2009 | 04:29 PM
sean coleman's Avatar
what is needed to run a supercharger with nitrous. say i already have a cam intake and headers and a blown carb. the motor is a mild stoke 350. 5.7L advice would be nice thank you
Old Nov 5, 2009 | 05:19 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: super charge with nitrous
A hope and a prayer.
But no really, one or the other is usually the way to go. If you were to run both you would need the best forged internals you can get and low compression.
A "mild" 350 won't cut the mustard.
Old Nov 5, 2009 | 06:24 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
If you're going to run any boost at all, it's going to take all top shelf components!!!! Aftermarket block, billet crank and rods, 2618 pistons, ZG rings, and some really, really first rate machine and assembly work..... Not just a check it with plastigage and run it operation---if you want it to live....
Old Nov 5, 2009 | 09:55 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
True that. If your gonna put boost to that motor i would get some nice blower pistons, usually you want to start with a motor with lower compression if you are gonna put boost to it. Also make sure you get a a forged steel crank and billet main caps, or between the boost and nitrous that motor won't last long.
Old Nov 6, 2009 | 11:23 AM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
i run a 75shot on my car to cool down the air charge with 10lbs of boost from a 142 weiand blower, i have a stock bottom end and havent had any problems with it. when it goes lean is where your going to run into problems
Old Nov 7, 2009 | 11:22 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
They compliment one another. The nitrous cools down the intake charge from the blower. But - Even with a forged bottom end, it'd better be tuned right. Don't allow it to go lean, and keep the timing backed down enough so it doesn't detonate. Also as mentioned, lower compression pistons will help squeeze more power out of that combo and stay safe....
Old Nov 7, 2009 | 12:19 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
what the last two people said. Its all in the tune. There are a few people running GOBS of boost on stock blocked lower ends and doing fine.
I need to finish plumbing my nitrous.
I have a fully forged 383 with a novi 2000 pulled for 12psi. and a 125 shot on top of that.(again to cool the intake charge)
Old Nov 16, 2009 | 08:41 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
forged internals. you need something to withstand all of the boost/laughing gas that you are throwing down that thing.
no green
Jan 9, 2016 09:22 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
Dragonsys
Sep 25, 2015 03:51 PM
