Blower???
Car: 1991 Chevy Camaro RS
Engine: 350 Crate Motor
Axle/Gears: 9-bolt Limited Slip
Blower???
have a 1991 camaro with 350 carb crate motor, was wondering what would be the best blower i can get for the a decent priece and where to order it from?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Blower???
.... if your planning on staying w/carb, you can't beat one of these for the price;
https://www.thirdgen.org/weiand142install
http://www.summitracing.com/parts/WND-6500-1/
Re: Blower???
im looking to keep it carbed and make about 400hp and spend 2,500$ i believe the car right now is making somewhere around 280-290hp
Re: Blower???
There is no "cheap" way to do a blower. While I have a Weiand 142 on my engine, like was posted above, the engine has to be set up for a blower (mainly lower compression, but also a blower-friendly cam) and there is the little matter of having a cowl hood big enough to fit it under (4" cowl hood minimum for 3rd Gen).
A centrifugal setup would fit under the stock hood, but you still have to have the motor built for boost and there is the added expense of a blow-through modified carb to work with it.
To hit 400HP doesn't require a blower. You can hit that N/A with modern aftermarket heads and cams without great difficulty.
Re: Blower???
Originally Posted by Adrenaline91RS
im looking to keep it carbed and make about 400hp and spend 2,500$ i believe the car right now is making somewhere around 280-290hp....
Re: Blower???
.... here is a documented build with pics. I believe there are some videos in there too;
https://www.thirdgen.org/forums/powe...-383-pics.html
Car: 77 and 79 Vette 85 Jag 93 Chevy p/u
Engine: 350 all tpi in vettes and jag tbi i
Transmission: 700r4 all but pu is 4l60e
Re: Blower???
i have a 142 weind blower on my 350 with 10-1 compression msd6btm and am very pleased with the engine combo but having problems with u-joints in vette rear end was even thinking of losing the blower to save the u-joints
codeysabatini
Nov 10, 2015 04:07 PM
buckeyecelt
Sep 24, 2015 05:50 AM
