Leaner with warmer outside temp??
Old Apr 8, 2010 | 12:19 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I had the car out three months ago when it was 40*. I took it out two weeks ago when it was 65 and it went lean by a full point. Lost power too. Nothing was changed except a bigger s/c pulley to lower boost a little until I get it properly re-tuned again.
I'm using a blow through mighty demon and 9psi. I even have some meth added to the mix and my rear jets are 97. A few months ago, it was perfect at 12.9:1, now its like 13.8-14.2. Meth is working. Power does drop so its not a sensor or gauge fault. This crappy barry grant can't be THAT inconsistent can it?
Old Apr 8, 2010 | 12:23 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Leaner with warmer outside temp??
yes it can ... have you ever turned to a drag racing show on TV... the first thing they say, TODAY WHAT A PERFECT DAY FOR RACING... nice and cool.... I would say yes it can affect the performance...
Old Apr 8, 2010 | 12:27 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Yes cooler air is good for performance, I'm wondering why a 25* (roughly) would give me an afr fluctuation of more than a full point. I don't think that is normal, this is dangerous and I'm wondering if I should be looking for a problem.
Old Apr 8, 2010 | 06:37 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Its leaner when its colder (denser air), and richer when it's warmer (less dense).
That's why dumbasses who don't re jet their sleds when its 0* out melt them down
Old Apr 8, 2010 | 07:32 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Sigh.
Correct again thank you. That is why I post this question. IT IS LEANER WITH WARMER TEMPS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Don't read what you want to read, read what I posted. Some people might call one a dumbass for not being able to properly read the only language they are fluent in.
Old Apr 9, 2010 | 10:54 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Originally Posted by Batass
Sigh.
Settle down. I obviously read the post. I'm saying that what you're seeing is completely opposite of what I've ever encountered.
Read my post, cold air is denser than warm air, so when it's warmer it should be fatter. You're saying that the a/f was leaner when the air temp increased...which doesn't make any sense to me.
Old Apr 9, 2010 | 11:27 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
CHILDREN, do you two need a timeout?
Old Apr 11, 2010 | 10:29 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
It doesn't make any sense to me either, so I'm looking for some clues as to why. I got a tip that it could be a fluttering power valve.
You stated the reason I made the post. Many people are quick to spout/show off what they know without ever stating any relevant information. I just have a low tolerance for that, I'm sorry if its a fault. A little.
Old Apr 12, 2010 | 12:21 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Sorry about that, my bad. I assume the fuel pressure is the same, and wb sensor is good too. How big of a valve do you have in it now?
Old Apr 12, 2010 | 08:46 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I have a 6.5 in it. I pull around 13" of vacuum. I had a 5.5 in it and I had a rich cruise, so I went a little higher. The problem went away for a while but the car is rich on cruise again and lean at WOT. It really does sound like a powervalve. I'll have to pull it out when I get a chance.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
