turbo carb set up???
Old Apr 13, 2010 | 02:53 PM
Adrenaline91RS's Avatar
Car: 1991 Chevy Camaro RS
Engine: 350 Crate Motor
Axle/Gears: 9-bolt Limited Slip
Was looking into putting a turbo onto my car and was wondering what kind of carb set up i want to go with, can anyone help me out here??? and if could post pics of setups or links to some. Thanks
Old Apr 13, 2010 | 05:29 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Re: turbo carb set up???
you wanna go with a blow thru carb and a rising fuel pressure regulator 1:1. Alot of great info on both this forum and turbomustangs.com on blow thru carbs. If you give us more info on what you want to do with the car hp goals and stuff we can point you in the right direction
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
midge54
Jan 29, 2017 07:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
