Fastburn heads for turbo?
Old Apr 20, 2010 | 09:04 PM
F-Body Demon's Avatar
Hey guys quick and simple here I wanted your opinions on using GMs Fastborn cylinder heads on a 383 miniram turbo setup. They are 210cc and 62cc chamber.
Issues I can see are the deck possibly not being thick enough.
That and the valves are slightly smaller which is going to put greater stress on the exhaust valve, however I believe the fastburn heads run sodium filled valves. Opinions?
The miniram I have to use is a miniram III so I am limited to Vortec style heads, the best of which being the fastburns.
Old Apr 20, 2010 | 09:45 PM
Drac0nic's Avatar
Re: Fastburn heads for turbo?
biggest issue I can see is 383 CID with 62cc chambers. That could cause a rather high static compression ratio quite frankly.
Old Apr 23, 2010 | 06:45 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
the heads are fine, i know a guy at my local track right now running a set on a 350 with a procharger(P1-SC model) @ 12psi. All you have to do is buy the right pistons to put your compression where you want it...thats if you already have the heads and you're building the motor from scratch.
Old Apr 25, 2010 | 09:31 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
Engine: 383 waiting on afr 195 comps
Axle/Gears: 3.42 Posi
Sorry man I dissagree. The best vortech style head for the money is the etec 200 edelbrock head. The best vortech style period is the new afr vortech heads but it is a lot more expensive. The fastburn is an old casting that has been out performed many times. I have a set of the 200cc etecs sitting on my bench for sell currently. I went with the afr 195 comp heads for my new setup but the edelbrocks did very well on my 383. Shoot me a pm if you want any specs on the etecs. I'd make you a great deal on them too.
Old May 1, 2010 | 01:31 PM
I said if he already HAVE the heads, go ahead and use them, i've seen them make great power on very "basic" combos. The thread wasn't about comparing heads....on the other hand, i've seen high dollar heads on motors that don't run worth a ****! decent heads are vital to making power but there's more to it.
Old May 1, 2010 | 10:19 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
Yeah dude wasn't talking to you. I was responding to the author saying the best vortech option was the fastburn heads. I originally intended on paying those heads for my project years ago but did the research and found the etecs were a superior product and cost less than the gm fastburns. I would agree that you dont need high dollar heads to make good power (especially with a forced induction setup ) As stated previously, if you already have the fastburn heads, great, if not you should know there are better options out there. My
Old May 2, 2010 | 06:56 PM
my mistake boss
Terrell351
Jun 13, 2021 01:13 PM
509 camaro fan
Sep 6, 2015 10:43 AM
camaro71633
Sep 1, 2015 10:24 AM
86White_T/A305
Aug 17, 2015 12:16 AM
